    Two Duet 3 Mini 5+ and two toolboards over CAN
    • Proschi3Dundefined
      Proschi3D
      How do I connect these 4 boards over CAN together?
      Love my Duet 3 Mini.
      https://www.instagram.com/proschi3d
      https://youtube.com/@proschi3d
      https://www.proschi3d.de
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
        Start by getting the two mini5s talking to each other.
        https://docs.duet3d.com/en/User_manual/Machine_configuration/CAN_connection#mainboard-used-as-expansion-board
          Proschi3D @Proschi3D
          I already have the two Duet 5 mini running. I just don’t quite understand how I need to wire the tollboards in between. The 2nd duet should be at the end, right?
            I think I have understood it now?! I go from my first Duet 5 to the first toolboard, then CAN L and H are simultaneously also the output to the 2nd toolboard. From the 2nd toolboard the same then to the endboard Duet 5.
            dc42undefined 1 Reply Last reply Reply Quote 1
              dc42 administrators @Proschi3D
              @Proschi78 said in Two Duet 3 Mini 5+ and two toolboards over CAN:
              That's correct.
