    3.5.1 firmware - Last reset 08:29:26 ago, cause: software
    Beta Firmware
    • Aurimasundefined
      Aurimas
      @dc42 @gloomyandy
      guys can you please check this log?
      Last software reset at 2024-05-01 22:51, reason: HardFault imprec, Gcodes spinning, available RAM 14552, slot 1
      Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 489 ok
      Stack: 2002c610 20032460 200014e8 00000000 200335fd 0002ff99 0002feb0 610f6000 20035790 2002c5f8 200187fc 2002c41e 200187fc 2001e9f8 0003011f 00000000 00000000 00000000 200120a0 00000014 ffffffff 00000102 e1f10050 6a01a8c0 08000161 00000003 000347e1
      Error status: 0x04
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.1 (2024-04-19 14:41:25) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: AGMAV-AR6KL-K65J0-409N6-LGW1Z-7XF1B
      Used output buffers: 3 of 40 (40 max)
      Static ram: 103232
      Dynamic ram: 123704 of which 24 recycled
      Never used RAM 11144, free system stack 138 words
      Tasks: NETWORK(2,nWait 7,179.9%,212) HEAT(3,nWait 6,0.4%,328) Move(4,nWait 6,0.0%,244) CanReceiv(6,nWait 1,1.6%,774) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.1%,348) TMC(4,nWait 6,22.7%,68) MAIN(1,running,178.0%,665) IDLE(0,ready,0.0%,30) AIN(4,delaying,13.5%,260), total 396.3%
      Owned mutexes: WiFi(NETWORK)
      Error status: 0x04
      Aux0 errors 0,0,2
      MCU revision 3, ADC conversions started 30566118, completed 30566116, timed out 0, errs 0
      MCU temperature: min 20.9, current 21.5, max 23.6
      Supply voltage: min 23.3, current 23.7, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/8/8, gc cycles 0
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 104, read errors 0, write errors 1, ifcnt 52, reads 26185, writes 16, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstis 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 1, ifll, SG min 110, read errors 0, write errors 1, ifcnt 52, reads 26185, writes 16, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 1, ifcnt 46, reads 26187, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 1, ifcnt 46, reads 26187, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 46, reads 26187, writes 14, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: standstill, SG min 108, read errors 0, write errors 1, ifcnt 52, reads 26185, writes 16, timeouts 0, DMA errors 0, CC errors 0
      Driver 6: standstill, SG min 110, read errors 0, write errors 1, ifcnt 52, reads 26185, writes 16, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2024-05-02 07:21:22
      Slowest loop: 14.56ms; fastest: 0.10ms
      === Storage ===
      Free file entries: 18
      SD card longest read time 2.5ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 19, maxWait 30551940ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 18892 ticks, enabled
      Moves shaped first try 3, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Scheduled moves 6, completed 5, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
      === DDARing 1 ===
      Bed heaters 0 -1 -1 -1, chamber heaters 4 -1 -1 -1, ordering errs 0
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.0
      Movement locks held by HTTP, null
      HTTP is idle in state(s) 49 5, running macro
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x000080f
      Queue 0 has 'M106 P5 S0' for move 6
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 0
      Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 275128, received 1253276, lost 0, errs 0, boc 0
      Longest wait 2ms for reply type 6053, peak Tx sync delay 273, free buffers 26 (min 25), ts 152831/152830/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 14.20ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1.0
      MAC address e8:68:e7:e5:b1:d7
      Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 41416
      WiFi IP address 192.168.1.87
      Signal strength -39dBm, channel
      Australian design and build large scale 3d printers
      https://aurarum.com.au
      • gloomyandyundefined gloomyandy referenced this topic
        Has this happened again since?
        • Phaedruxundefined Phaedrux moved this topic from Firmware installation
