    M669 polar offset
    Documentation
    • jumpedwithbothfeetundefined
      jumpedwithbothfeet
      Evening all, apologies if this is in the wrong section, I’m currently building a polar printer and reading the config, M669 XY offsets are yet to be implemented, any idea when this is pencilled in for? Or maybe someone knows away around it?
      6HC Voron Trident based, 6XD CNC, Mini 5 polar printer
        dc42 administrators @jumpedwithbothfeet
        @jumpedwithbothfeet we don't have a date set for implementing it, however you can work around it using the G10 L2 command to set workplace coordinate offsets.
        I have created Github issue https://github.com/Duet3D/RepRapFirmware/issues/993.
        dc42 created this issue in Duet3D/RepRapFirmware
        open Support XY coordinate offsets in M669 parameters for polar kinematics #993
        jumpedwithbothfeetundefined 1 Reply Last reply Reply Quote 1
          jumpedwithbothfeet @dc42
          @dc42 Many thanks, I'll take a look at G10 and try implementing it, I have attempted using G92 to offset the distance on the X axis but somethings amiss in my Gcode and it still hits the wrong spot!
            @jumpedwithbothfeet G92 won't do what you want.
