    config.g file created with RRF tool M350 Array too long error
    Config Tool
    • dlc60undefined
      dlc60
      This was my best guess for a place to ask this question.
      Details:
      Duet 2 Maestro
      F/W 3.5.1, Web 3.5.1
      RRF 3.5.0
      Printer: custom CoreXY with single extruder.
      Problem:
      I just updated my Maestro to firmware/web 3.5.1 and used the RRF config tool to build my initial config.g file.
      I got this error:
      Error in start-up file macro line 45: in file macro line 45 column 19: M350: array too long, max length = 0
      Line 45 doesn't have an M350, but there is one near there for the extruder. (attached config.g file)
      ; Extruders
      M584 E3 ; set extruder mapping
      M350 E16 I1 ; configure microstepping with interpolation
      M906 E1000 ; set extruder driver currents
      M92 E764 ; configure steps per mm
      M566 E120 ; set maximum instantaneous speed changes (mm/min)
      M203 E7200 ; set maximum speeds (mm/min)
      M201 E250 ; set accelerations (mm/s^2)
      My last RRF config file for another printer was from a prior version of RRF and this looks different, I am scratching my head. Can anyone see what is going wrong?
      Any hint appreciated. Be well,
      DLC
      config.g
      • Phaedruxundefined Phaedrux moved this topic from Tuning and tweaking
        Can you share your config.json file as well?
        dlc60undefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @dlc60
          @dlc60 I just updated my Maestro board with 3.5.1, and copied your config.g in to test it. I don't see this error, either at startup or if I run M98:
          M98 P"config.g"
          HTTP is enabled on port 80
          FTP is enabled on port 21
          Warning: Heater 0 predicted maximum temperature at full power is 321°C
          I think this is more likely to be an SD card reading issue, maybe a bad block on the SD card. Try reformatting the SD card, or try a new one, and copy the configuration files fresh back on to it. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card for formatting and SD card structure guidance.
          • dlc60undefined
            dlc60 @Phaedrux
            @Phaedrux said in config.g file created with RRF tool M350 Array too long error:
            Sure, here you go.
            be well
            configtool.json
