    Question: Array Assignment
    Gcode meta commands
    1.3k
    • DonStaufferundefined
      DonStauffer
      I'm having some intermittent problems with array corruption; the resulting error is "expected numeric operands". Very complex system of macros so I'm not sure how to distill the problem to a simple macro. This is code ultimately run by daemon.g during a G32.
      I have isolated that the problem happens in this code, which is a small part of one macro. I've added variables as part of my debugging so it's a bit verbose now.
      global.NeoPixColor[var.PEND][var.LEDNum] contains a 3-element array of RGB values, except that instead of that array, an element may be null. "Pending" arrays may all be null instead of 3-element 1D arrays, but "Color" should never be null.
      What happens specifically is that the last line inside the inner loop usually works fine - about 99 out of 100 times - but that one time, the assignment makes seemingly random other elements of Pending contain null. So, iterations might equal zero, and before the assignment, Pending[1] contains a number, and after it contains null. or it might be element 2. Or it might happen when assigning to element 1. The actual error occurs later when I try to use the element expecting it to contain a number; I think I tried the isnan function but oddly, it also gave me "expected numeric operand".
      var LEDNum = 0
      var Pending = 0
      var PendingOld = null
      var Clr = null
      var PendingNew = null
      while iterations < var.Count
          set var.LEDNum = var.Start + iterations
          set var.Pending = global.NeoPixColor[var.PEND][var.LEDNum]
          if var.Pending == null
              set var.Pending = {0, 0, 0}
          while iterations < #var.Color
              set var.PendingOld = var.Pending[iterations]
              set var.Clr = var.Color[iterations]
              set var.PendingNew = var.PendingOld + var.Clr
              set var.Pending[iterations] = var.PendingNew
          set global.NeoPixColor[var.PEND][var.LEDNum] = var.Pending
      Besides wondering what might be going on here, I returned to a question I had when I started working with arrays. Initially I just experimented and went with what seemed to work. I got the impression any of these were OK, and I assumed RRF took care of memory allocation and freeing as needed, but now I wonder:
      var MyArray1 = {{0, 2}, {3, 4}}
      set var.MyArray1[0][0] = 1
      var MyArray2 = vector(2, vector(2, 0))
      set var.MyArray2[0][0] = 1
      set var.MyArray2[0][1] = 2
      set var.MyArray2[1][0] = 3
      set var.MyArray2[1][1] = 4
      var MyArray3 = {{0, 2}, {3, 4}}
      var MyArray4 = var.MyArray3[1]
      var MyArray5 = {{0, 2}, {3, 4}}
      var MyArray6 = 0
      set var.MyArray6 = var.MyArray5
      var MyArray7 = {{0, 2}, {3, 4}}
      var MyArray8 = null
      set var.MyArray9 = var.MyArray7
      So, what are the rules for array initialization and assignment? How does memory allocation for arrays work? What does the underlying storage look like?
      DonStaufferundefined 1 Reply Last reply Reply Quote 0
        DonStauffer @DonStauffer
        @DonStauffer I'm also getting random reboots when running these macros, but not at the same place as this error.
        Added some output to show the problem:
            echo "LED Num=",iterations
                echo "Pend=",var.Pending
                echo "PendingOld=",var.PendingOld,"Clr=",var.Clr,"Pend=",var.Pending,"iters=",iterations
                echo "Almost Bot Pend=",var.Pending
                echo "Bot Pend =",var.Pending
            echo "Pending=",var.Pending
        Log:
        LED Num= 7
        Pend= {0,0,0}
        PendingOld= 0 Clr= 0 Pend= {0,0,0} iters= 0
        Almost Bot Pend= {0,0,0}
        Bot Pend = {0,0,0}
        Pend= {0,0,0}
        PendingOld= 0 Clr= 32 Pend= {0,0,0} iters= 1
        Bot Pend = {0,32,0}
        Pend= {0,32,0}
        PendingOld= 0 Clr= 16 Pend= {0,32,0} iters= 2
        Almost Bot Pend= {0,32,0}
        Bot Pend = {0,32,16}
        Pending= {0,32,16}
        LED Num= 8
        Pend= {0,0,0}
        Bot Pend = {0,null,}
        Pend= {0,null,}
        PendingOld= null Clr= 32 Pend= {0,null,} iters= 1
        Error: in file macro line 58 column 54: meta command: expected numeric operands
        I'm also curious why "Bot Pend" shows {0,null,} instead of, for instance, {0,null,null}.
          @DonStauffer Ran these macros a couple times without error, then ran again and got this log. You can see the effect is unpredictable and not reproducable:
          Log:
          LED Num= 4
          Pend= {0,0,0}
          Bot Pend = {0,null,null}
          Pend= {0,null,null}
          PendingOld= null Clr= 0 Pend= {0,null,null} iters= 1
            dc42 administrators @DonStauffer
            @DonStauffer please provide the declarations of the missing variables so that we can try to reproduce this. For example: var.Count, var.PEND, global.NeoPixColor.
            It would also be worth running M122 to check whether it still reports "Heap OK", or reports a heap error.
            DonStaufferundefined 3 Replies Last reply Reply Quote 0
              DonStauffer @dc42
              ;	AddNeoPix
              ;	Adds color values to pending NeoPixel LED color values.
              ;   Does no I2C communication. Call SendNeoPix to update via I2C, and
              ;   ShowNeoPix to display changes.
              ;	Parameters
              ;		C	Color Array {R, G, B}
              ;		S	Starting LED Number
              ;		N	Number of LEDs to Set
              ;	Don Stauffer							April, 2024
              echo "AddNeoPix C",param.C," S", param.S, " N", param.N
              ;   Constants
              var PEND = 1
              ;   Parameters
              var Color = {0, 0, 0}
              var Start = 0
              var Count = global.NeoPixLEDCount
              if exists(param.C)
                  set var.Color = param.C
              if exists(param.S)
                  set var.Start = param.S
              if exists(param.N)
                  set var.Count = param.N
              ;   Add to pending color values, to be sent later
              var LEDNum = 0
              var Pending = vector(3, 0)
              var PendingOld = vector(3, 0)
              var Clr = vector(3, 0)
              var PendingNew = vector(3, 0)
                  echo "LED Num=",var.LEDNum
                      ;echo "PendingNew=",var.PendingNew
              echo "Exiting AddNeoPix"
                @DonStauffer All this macro does is take the RGB color array in param.C, and for each of param.N LEDNum value starting from param.S, updates global.NeoPixColor[1][LEDNum]. The update simply adds the 3 elements from param.C to the corresponding elements of each of those global.NeoPixColor elements; if a global.NeoPixColor element is null, the value in param.C replaces that element.
                So, M98 P"...AddNeoPix" C{1, 2, 3} S5 N3 should effectively do this:
                if global.NeoPixColor[1][5] == null
                    set global.NeoPixColor[1][5] = param.C
                else
                    set global.NeoPixColor[1][5][0] = global.NeoPixColor[1][5][0]+param.C[0] ; add 1
                    set global.NeoPixColor[1][5][1] = global.NeoPixColor[1][5][1]+param.C[1] ; add 2
                    set global.NeoPixColor[1][5][2] = global.NeoPixColor[1][5][2]+param.C[2] ; add 3
                if global.NeoPixColor[1][6] == null
                    set global.NeoPixColor[1][6] = param.C
                else
                    set global.NeoPixColor[1][6][0] = global.NeoPixColor[1][6][0]+param.C[0] ; add 1
                    set global.NeoPixColor[1][6][1] = global.NeoPixColor[1][6][1]+param.C[1] ; add 2
                    set global.NeoPixColor[1][6][2] = global.NeoPixColor[1][6][2]+param.C[2] ; add 3
                if global.NeoPixColor[1][7] == null
                    set global.NeoPixColor[1][7] = param.C
                else
                    set global.NeoPixColor[1][7][0] = global.NeoPixColor[1][7][0]+param.C[0] ; add 1
                    set global.NeoPixColor[1][7][1] = global.NeoPixColor[1][7][1]+param.C[1] ; add 2
                    set global.NeoPixColor[1][7][2] = global.NeoPixColor[1][7][2]+param.C[2] ; add 3
                  DonStauffer @dc42
                  @dc42 It seems like the Duet rebooted after the error, so I don't know if this is useful. Trying to get an M122 after the error but without a reboot between. Will post if successful.
                  5/15/2024, 11:59:10 AM M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S06Q-9AY7D
                  Used output buffers: 3 of 26 (23 max)
                  Static ram: 23256
                  Dynamic ram: 75600 of which 0 recycled
                  Never used RAM 11432, free system stack 182 words
                  Tasks: NETWORK(1,ready,13.5%,215) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,359) DUEX(5,nWait 5,0.0%,19) MAIN(1,running,86.4%,703) IDLE(0,ready,0.0%,29), total 100.0%
                  Owned mutexes:
                  Last reset 00:44:07 ago, cause: software
                  Last software reset at 2024-05-15 11:15, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 824, slot 0
                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00417803 BFAR 0x6d754e40 SP 0x20002568 Task MAIN Freestk 1151 ok
                  Stack: 6d754e44 6d754e40 200027a3 00000017 ffffffff 0045d6a7 004663aa 210e0000 00410f21 20002784 00000017 20002684 20002784 00000002 00000000 00000001 00411491 00000000 20002680 20002688 00000001 00000000 00000001 a5a5a5a5 00000000 454c000c 6d754e44
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU temperature: min 42.9, current 43.3, max 46.9
                  Supply voltage: min 24.0, current 24.1, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 99/35, heap memory allocated/used/recyclable 2048/1188/56, gc cycles 1
                  Events: 0 queued, 0 completed
                  Driver 0: standstill, SG min n/a
                  Driver 1: standstill, SG min n/a
                  Driver 2: standstill, SG min n/a
                  Driver 3: standstill, SG min n/a
                  Driver 4: standstill, SG min n/a
                  Driver 5: standstill, SG min n/a
                  Driver 6: standstill, SG min n/a
                  Driver 7: standstill, SG min n/a
                  Driver 8: standstill, SG min n/a
                  Driver 9: standstill, SG min n/a
                  Driver 10:
                  Driver 11:
                  Date/time: 2024-05-15 11:59:09
                  Slowest loop: 8.79ms; fastest: 0.19ms
                  === Storage ===
                  Free file entries: 10
                  SD card longest read time 2.1ms, write time 0.0ms, max retries 0
                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                  no step interrupt scheduled
                  Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                  === DDARing 0 ===
                  Heater 1 is on, I-accum = 0.0
                  Movement locks held by null
                  HTTP is idle in state(s) 0
                  Telnet is idle in state(s) 0
                  File is idle in state(s) 0
                  USB is idle in state(s) 0
                  Aux is idle in state(s) 0
                  Trigger is idle in state(s) 0
                  Queue is idle in state(s) 0
                  LCD is idle in state(s) 0
                  Daemon is idle in state(s) 0
                  Q0 segments left 0
                  Code queue 0 is empty
                  === Filament sensors ===
                  check 0 clear 21909205
                  Extruder 0 sensor: no data received
                  Extruder 1 sensor: no data received
                  === DueX ===
                  Read count 1, 0.02 reads/min
                  === Network ===
                  Slowest loop: 8.52ms; fastest: 0.00ms
                  Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 1 of 8
                  === WiFi ===
                  Interface state: active
                  Firmware version 2.1.0
                  MAC address 84:f3:eb:83:47:be
                  Module reset reason: Power up, Vcc 3.36, flash size 4194304, free heap 42792
                  WiFi IP address 192.168.1.130
                  Signal strength -45dBm, channel 11, mode 802.11n, reconnections 0
                  Clock register 00002002
                    @DonStauffer
                    This was after a run which had multiple losses of WiFi connectivity, which has been happening a lot lately, but afterward it still showed as Homed, so it must not have rebooted.
                    5/15/2024, 12:08:43 PM M122
                    Used output buffers: 12 of 26 (26 max)
                    Static ram: 23256
                    Dynamic ram: 80072 of which 224 recycled
                    Never used RAM 952, free system stack 116 words
                    Tasks: NETWORK(1,ready,15.1%,215) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,298) DUEX(5,nWait 5,0.0%,19) MAIN(1,running,84.0%,703) IDLE(0,ready,0.8%,29), total 100.0%
                    Owned mutexes:
                    Last reset 00:53:40 ago, cause: software
                    Error status: 0x0c
                    Aux0 errors 0,0,0
                    MCU temperature: min 43.0, current 46.3, max 46.4
                    Supply voltage: min 24.0, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                    Heap OK, handles allocated/used 297/68, heap memory allocated/used/recyclable 6144/2808/840, gc cycles 264
                    Driver 0: standstill, SG min 0
                    Driver 1: standstill, SG min 0
                    Driver 5: standstill, SG min 0
                    Driver 6: standstill, SG min 0
                    Driver 7: standstill, SG min 0
                    Driver 10:
                    Driver 11:
                    Date/time: 2024-05-15 12:08:42
                    Slowest loop: 20.69ms; fastest: 0.10ms
                    === Storage ===
                    Free file entries: 9
                    SD card longest read time 15.4ms, write time 0.0ms, max retries 0
                    DMs created 83, segments created 3, maxWait 2785753ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                    === DDARing 0 ===
                    Scheduled moves 109, completed 109, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 4], CDDA state -1
                    Daemon is doing "G4 P{global.DaemonPeriod}" in state(s) 0 0, running macro
                    Q0 segments left 0
                    check 0 clear 25655011
                    === DueX ===
                    Read count 0, 0.00 reads/min
                    === Network ===
                    Slowest loop: 21.15ms; fastest: 0.07ms
                    === WiFi ===
                    Signal strength -41dBm, channel 11, mode 802.11n, reconnections 0
                      DonStauffer @dc42
                      @dc42 More information:
                      (EDIT: I SPOKE TOO SOON. Still getting array corruption, or at least the "expected numeric operand" even without nan param)
                      (EDIT: Confirmed that array corruption is still happening.)
                      I've been doing some troubleshooting and discovered the macro is sometimes receiving "nan" for the S and/or N parameter(s). This shouldn't happen and was due to an uninitialized global value used to calculate those parameters by the calling macro. So far, it seems like correcting that error prevented nan in the parameters and eliminated the array corruption.
                      It's possible this should have resulted in RRF reporting an error somewhere, but it seems like it should have done that before corrupting array contents, though I haven't analyzed how nan would affect this macro. It also seems like it should probably either have caused an error or (if there was nothing syntactically or semantically illegal) not, rather than only causing one occasionally, although again, it's possible there's a logical reason for this. Maybe the use of nan in certain contexts should just generate an error that you can't do that, if it's letting you do it now.
                      I'm also still interested in whether my assumptions about array initialization and assignment are correct, and how the nuts and bolts work.
                        @DonStauffer how should I initialise global.NeiPixColor ?
                        DonStaufferundefined 2 Replies Last reply Reply Quote 0
                          DonStauffer @dc42
                          var SENT = 0
                          var PEND = 1
                          global NeoPixLEDCount = 28
                          global NeoPixColor = vector(2, vector(global.NeoPixLEDCount, vector(3, 0)))
                          set global.NeoPixColor[var.PEND] = vector(global.NeoPixLEDCount, null)
                          NeoPixColor[0] holds the color already transmitted to each LED, to avoid resending data unnecessarily. NeoPixColor[1] collects updated colors for each LED, to send them all at once for efficiency. The elements are initialized to null, meaning "there is nothing to send".
                          I2C is a slow way to update NeoPixels. This is an attempt to eliminate some communication overhead. So AddNeoPix sums the colors sent to it for each LED, then there's a SendNeoPix macro which sends the LED colors from the "pending" part of the array, if they exist (are not null) and are not the same as the "sent" part of the array (NeoPixColor[0]). The colors get added to the pending part of the array rather than replacing existing values there, to aid in color blending, for displaying overlapping ranges of LEDs in different colors, with the middle a blend of the 2 colors.
                          The problem probably happens less than 1% of calls to AddNeoPix. Running bed leveling probably calls it a couple hundred times, and about half of bed levelings will produce the error. Most recent (cleaned up) code & log; it appears as though the assignment of one element of the RGB array corrupts another element (happens randomly; not always element 0 corrupting 1, or even an earlier element corrupting a later one). Not "line 56" in the error refers to what is line 21 in the snippet.
                          var LEDNum = null
                          var Pend = null
                              set var.Pend = global.NeoPixColor[var.PEND][var.LEDNum]
                              ;   Check for null pending RGB array
                              if var.Pend == null
                                  set var.Pend = {0, 0, 0}
                              ;   Add new color value to pending
                              echo "LED#",var.LEDNum,": Pend1=",var.Pend, "Color=",var.Color
                                  echo "Pend[i]=",var.Pend[iterations], "Color[i]=",var.Color[iterations]
                                  set var.Pend[iterations] = var.Pend[iterations] + var.Color[iterations]
                              echo "Pend2=",var.Pend
                          Log
                          LED 22 : Pend1= {0,0,0} Color= {0,32,16}
                          Pend[i]= 0 Color[i]= 0
                          Pend[i]= 0 Color[i]= 32
                          Pend[i]= 0 Color[i]= 16
                          Pend2= {0,32,16}
                          Exiting AddNeoPix
                          AddNeoPix C {0,0,0} S 23 N 5
                          LED# 23 : Pend1= {0,0,0} Color= {0,0,0}
                          Pend[i]= null Color[i]= 0
                          Error: in file macro line 56 column 80: meta command: expected numeric operands
                            DonStauffer @dc42
                            @dc42 Workaround, tested a dozen runs with no errors; avoids subscripted assignment of RGB array elements by using 3 discrete variables to build an array to assign in its entirety:
                            var LEDNum = null
                            var Pend = null
                            var r = null
                            var g = null
                            var b = null
                                if var.Pend == null
                                set var.r = var.Pend[0] + var.Color[0]
                                set var.g = var.Pend[1] + var.Color[1]
                                set var.b = var.Pend[2] + var.Color[2]
                                set var.Pend = {{var.r},{var.g},{var.b}}
                              @DonStauffer I believe I have identified an issue when using 'set' to assign an element in an array of arrays, where the nested array whose element is being assigned is a copy of another array. I have created this issue https://github.com/Duet3D/RepRapFirmware/issues/1008.
                              Using 'set' with only a single array index should always be safe. For example, I think the following may be unsafe if global.myarray[1] is a copy of another array:
                              set global.myarray[1][2] = 1
                              whereas the following would be safe:
                              var tempArray = global.myArray[1]
                              set var.tempArray[2] = 1
                              set global.myArray[1] = var.tempArray
                              dc42 created this issue in Duet3D/RepRapFirmware
                              closed Bug: setting elements of nested arrays sometimes goes wrong #1008
                                DonStauffer @dc42
                                @dc42 Off the top of my head, that sounds like exactly the workaround I tried which didn't work. What ended up working as a workaround was avoiding subscripted assignment to the subarray, but instead constructing the array from discrete variables like
                                set global.myArrayrray[1] = {var.A, var.B, var.C}
                                I'll look back through my notes and see if I'm remembering right.
                                EDIT: Ah, I sort of "half" did it. I was using an array with an array element with an array element, so the original workaround attempt did start with two subscripts. Maybe that was why it didn't work. Anyhow, my workaround reconstructing the subarray "manually" without subscripts did work, so I'm not stuck any more.
                                Intermittent problems are tough to trouble shoot. BTW, error messages often don't name the macro they're referring to even when they give line numbers. If it's a complicated tree of nested M98 calls, it only names the outermost one and I have to go searching through the branches. The name of the macro the offending line is actually in would really help.
                                  droftarts administrators @DonStauffer
                                  @DonStauffer said in Question: Array Assignment:
                                  It’s been requested before, but can be quite a memory intensive process. See https://github.com/Duet3D/RepRapFirmware/issues/771
                                  T3P3 created this issue in Duet3D/RepRapFirmware
                                  open Busy status to include the macro file that is running when busy #771
                                  DonStaufferundefined 1 Reply Last reply Reply Quote 1
                                    DonStauffer @droftarts
                                    @droftarts Option or command to dump call stack maybe?
                                    • gloomyandyundefined
                                      gloomyandy @DonStauffer
                                      You can always create that yourself. Have a global array that you push and pop the name of the macro to and print it out if when you need to. Or just echo the name of the macro at the start may be enough.
                                        DonStauffer @gloomyandy
                                        @gloomyandy Kind of what I'm doing now. I put something like "echo "MyMacroName" at the beginning of each macro, and "Leaving MyMacroName" as the last line. That clutters the log, but I'm thinking maybe something like:
                                        In config.g:
                                        global CallStack = vector(<nice large number>, "")
                                        global CallStackDepth = 0
                                        Then, presumably at the outermost level of whatever I'm running:
                                        set global.CallStackDepth = 0
                                        Then in my macro:
                                        set global.CallStack[global.CallStackDepth] = "MyMacroName"
                                        set global.CallStackDepth = global.CallStackDepth + 1
                                        set global.CallStackDepth = global.CallStackDepth - 1
                                        When I needed it, I could run a DumpCallStack macro:
                                        while iterations < global.CallStackDepth
                                            echo global.CallStack[iterations]
                                        Maintaining the global.CallStackDepth = 0 could be bothersome when running a macro separately from a stack of macros, but at least it's only one simple line. But a bigger problem would be that an error may abort only the macro it's in, and the calling macro then continues. So CallStackDepth will be left too high in that case. Besides that functional problem, the stack would get more added to it after the error, leaving me unable to tell where the error was - the whole point of the stack trace. If there were a way to know about the error and do something when it occurs, this could be solved, but I don't know of a way. I'm not sure when execution continues vs. the entire call stack aborts (in which case this scheme works). I just assumed it was whether execution could continue, based on the severity of the error.
                                        I wonder how much processing overhead this would take as compared with a compiled-in RRF solution.
                                          @DonStauffer The thing is it takes zero amount of memory and adds zero overhead for the many folks who do not need it. That would not be the case for a firmware based solution. Plus you get to use it now rather than waiting for anyone else to implement it and you can tailor it to your needs.
                                          I suspect just echoing the name of the function at the start of a macro is enough for most situations.
                                            @gloomyandy That's what I'm doing now, but it's got some problems. Iterative calls add sometimes thousands of lines to the console log, and I have to keep adding and removing these lines of code as I go back and edit macros. I've gotten so I just comment them out and leave them there for the future. But the log clutter is problematic.
