    What G code to try out Z offset when Z0 against heatbed before print?.
    • Crille
      Crille last edited by
      Hey all
      Is there any G code used to test
      the distance from the nozzle to the heating bed ?.
      I have been looking for it, but I may have missed it in everything.
      I would like to know that the nozzle goes down so you just get a piece of paper
      under the nozzle.
      As it is now, the nozzle goes into the heating bed, even though I have made all the settings
      and uses IR sensor.
      I have one kossel printer with duetwifi FW1.20 and IR sensor from same maker.
      Thanks in advance.
        To measure that distance, you would need to detect when the nozzle just grips a piece of paper. How do you propose to do that?
        The recommended way of finding the trigger height is:
        1. Lower the nozzle in increasingly fine steps until it just grips the paper.
        2. Send G92 Z0 to define that height as Z=0.
        3. Use the jog buttons to raise the nozzle 5mm, and remove the paper.
        4. Send G30 S-1
        The S-1 parameter tells the firmware not to reset the Z=0 level but to report the height at which the probe triggered instead.
        • Crille
          @dc42:
          4. Send G30 S-1
          Thanks for info 🙂
          Did try it but still when it will start to print it go down in heatbed and scraping the nozzle.
          I have G32 i startcode before it start to print.
          What is it i do wrong?.
          • Crille
            2.24 is when ir probe gets triggered, this value i have in config.g also..
            Can it be config-overide.g that make this problem?..
            Start to think i have forgotten something when i make files.
