    Duet2 wifi stuck repeating Wifi Error.
    2.9k
    • zBeebleundefined
      zBeeble
      OOB ... looking at your debug message ... you could probably significantly cut binary size by cutting /home/renz/Projects from the path of all debug messages --- ie: cut to the root of the project.
      • zBeebleundefined
        zBeeble
        OK. Now it's full-on inaccessible.
        Lots of these lines scrolling on the console.
        ResponseTimeout, pending=1
        WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
        • zBeebleundefined
          zBeeble
          And just to be clear, two local computers are pointing at it and no network traffic (as expected) is coming from the router for it.
          • zBeebleundefined
            zBeeble
            This is the log from the first few glitches above (posted here) through starting a new print and then it glitching hard:
            Debugging enabled for modules: WiFi(14 - 0xffffffff)
            Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unus
            ed(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Exp
            ansion(18)
            Done printing file
            Finished printing file 0:/gcodes/CFFFP_DeckStand_Anker.gcode, print time was 13h 4m
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            ResponseBusy
            • zBeebleundefined
              zBeeble
              I delivered m111 p1 s1, and this is the changed repeating output:
              1ResponseTimeout, pending=1
              WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Con^?/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578
              WiFi: /hom^?s/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
              Debugging enabled for modules: Network(1 - 0xffffffff) WiFi(14 - 0xffffffff)
              Debugging disabled for modules: Platform(0) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unused(8) Print
              Monitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Expansion(18)
              Bad recv status size
              WiFi: /home/renz/Projec^?/home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
              WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Con^?uet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
              WiFi: /home/renz/Projects/^?t 80 already 4 conns
              WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on po^?/Connection.cpp(578): refused conn on port 80 already 4 conns
