    New Duetwifi fan/endstop problems (Solved)
    1800
    • Saltlife716
      Saltlife716 last edited by
      Hey guys, I did try searching through and couldn't find anything on this specific matter. I may have found something for the fans, but not sure until I get home.
      1. "Always On" fans and variable fans not working. Tried 5 different confirmed good fans and none of them are working. Not home to check but will check contacts with meter to verify power.
      2. Optical Endstops not triggering. 3 wire optical endstop, 3.3v going to positive on endstop, gnd going to gnd and signal going to signal. Used RRF configurator and have endstops set to high endstop and normally closed. During "home all" carriages go up but continually crashes into top, skipping belt teeth. When I go to only home x, y, or z, all carriages move.
      When I get home I'll post up my config file as well as pictures of the board. Just wanted to get this on here for a little headset art on troubleshooting.
      I had to send the board in already because of fried motor driver, and I just received this one.
      Things I know.
      Endstops
      1. I had to rearrange pins on endstop connectors to match polarities.
      2. VIN, 3.3v, and 5v are all lit up
      3. Endstop trigger lights never light up, whether I have it set to NC, NO, or manually trigger endstop.
      Fans
      1. Tried multiple fans on both ALWAYS ON and variable pins, none worked
      2. Tried all fans on a RUMBA board, they all worked
      3. Fans show up on web control they just won't come on whether it's at 0% or 100%
      BI v2\. 5 Heavily modded
      Duet Wifi
      E3D v6 0.20mm
      FSR autoleveling
      • Saltlife716
        Alright, just got home.
        Updates:
        I do have 12v coming into the board
        Fans
        1. I have 9v coming to every fan port on the board.
        2. Have 9v getting to VIN on the V Fan select
        2. Fans not working
        Endstops:
        1. The endstops are still working with the RUMBA board
        2. Endstops not triggering on DuetWifi
        With what i'm seeing, i'm assuming it's something on the firmware not setup correctly by me.
        Here is my config.g
        ; generated by RepRapFirmware Configuration Tool on Fri Dec 29 2017 20:37:16 GMT-0500 (Eastern Standard Time)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P1 ; Set firmware compatibility to look like RepRapFirmare
        M665 R322.326 L450 B153.9875 H371.475 ; Set delta radius, diagonal rod length, printable radius and homed height
        M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Set active high endstops
        M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
        G31 P500 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
        M557 R153.9875 S20 ; Define mesh grid
        M92 X80 Y80 Z80 E663 ; Set steps per mm
        M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
        M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
        M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M563 P0 D0 H1 ; Define tool 0
        M550 PMG v1.0 ; Set machine name
        M552 S1 ; Enable network
        M587 S"The Salt's-2G" P"TheGoodLife!0716!" ; Configure access point. You can delete this line once connected
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        T0 ; Select first tool
        Here's my homedelta.g
        ; homedelta.g
        ; generated by RepRapFirmware Configuration Tool on Fri Dec 29 2017 20:37:15 GMT-0500 (Eastern Standard Time)
        G91 ; relative positioning
        G1 S1 X405 Y405 Z405 F1800 ; move all towers to the high end stopping at the endstops (first pass)
        G1 X-5 Y-5 Z-5 F1800 S2 ; go down a few mm
        G1 S1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
        G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
        G90 ; absolute positioning
        G1 X0 Y0 F6000 ; move X+Y to the centre
        Duet Wifi
        E3D v6 0.20mm
        FSR autoleveling
          @Saltlife716:
          Fans
          2. Fans not working
          It sounds to me that there has been a short across one of the fan outputs on that board, which has fused the via in the PCB trace between VIN and the VIN pin of the fan voltage selector. If you are certain that you didn't cause the short, ask for another replacement board. Otherwise, you can bypass the trace using a wire on the back of the board; but make sure that the short won't happen again.
          @Saltlife716:
          Endstops:
          If the endstop lights on the Duet never light up, then either your optical endstops are not wired to the Duet correctly or they need to be modified to work on 3.3V. See the end of https://duet3d.com/wiki/Connecting_endstop_switches#3.3V-compatible_optical_endstop for the modification tyhat is sometimes needed to make optical endstops 3.3v-compatible.
          • Saltlife716
            Fans:
            To be honest, I may have caused the short, I never saw sparks or anything when i tested the pins, but I know the board was tested before it got sent to me. I'll try bypassing
            Enstops:
            I read the documentation you linked to me saying to replace the resistors. my R1 is already a 10k resistor, and R2 is a 1k resistor. I know how to solder, and test measurements, but i've never been good at telling how much resistance is needed where and, are those resistors too much you think?
            Duet Wifi
            E3D v6 0.20mm
            FSR autoleveling
            • Saltlife716
              Update:
              -Fans: Fans are working now on all pins.
              -Enstops: Not too sure what to do here. On the optical endstop it has a 10k resistor for R1, and a 1k for R2.
              Awesome thanks for that. I saw that post you submitted that said to jump VIN to VIN but I also had the endstops not working right and I didn't know how to checked to see if they were related or not, so i thought maybe it was something a little more complicated than that, luckily it wasn't lol.
              Duet Wifi
              E3D v6 0.20mm
              FSR autoleveling
              Ivogrundel 1 Reply Last reply Reply Quote 0
              • Saltlife716
                20171231_091024 by Sammy Saltalamacchia, on Flickr
                Sry about the size, wasn't sure to begin how to post it much less make it smaller lol
                This is one of my endstops.
                Pinout: +,-,sig (wires swapped on connector to match pinout on DuetWifi)
                3.3v coming into the endstop board
                Top resistor (R1) is a 10k resistor
                Bottom resistor (R2) is a 1k resistor.
                reading across the R1 resistor with endstop triggered is 0v, when it's not triggered it's 1.63v
                reading across the R2 resistor with endstop triggered is 2.18v, when it's not triggered it's 2.18v
                I should be getting 3.3v correct?
                Duet Wifi
                E3D v6 0.20mm
                FSR autoleveling
                • Saltlife716
                  I may have figured out the issue with the endstops maybe?
                  I looked at the RUMBA schematics and it feeds 5v to the endstops. Where the Duetwifi is sending it 3.3v.
                  Possible solutions
                  1. Remembering i know nothing about deciding what resistors should be used in anything, I could lessen the resistance on the boards…?
                  2. Going to be a bit janky.. but i could separate the endstops power, leaving just the GND and SIG on the endstops pins, and connect the powers to separate 5v pins in the board ( I see the 5v pin on the Panel Duo board (i may end up getting a Panel Duo in the near future), the 5v on the V FAN Jumper Select, and the 5v pin on the Jumper EXT 5v EN connector.
                  -or- is it something to where I can just twist the endstop powers together and route them into a single 5v pin?
                  Duet Wifi
                  E3D v6 0.20mm
                  FSR autoleveling
                    Leave the 10K resistor alone but replace the 1K resistor by a lower value. If you can tell me the part number of the slotted opto switch then I can work out an optimum value. However, 220 or 330 ohms should be suitable.
                    • Saltlife716
                      Awesome I will take it out and check for the PN. If I don't see how i'll just pop in a 330 first and check values.
                      Duet Wifi
                      E3D v6 0.20mm
                      FSR autoleveling
                      • Saltlife716
                        Ok I didn't see a PN number on the resistor. I swapped the 1k resistor for a 330 and now the endstops are working correctly. And the fans.
                        I just changed my z height in the system editor on the web control, clicked apply, it restarted the printer, but now the printer won't respond. It will come on, hotend fan (FAN1) will come on at the hotend, then turn off after 1-2 sec. And it won't connect to wifi to use web control. Connected it to YAT via USB, it connected, but failed when i tried to use M587 commands. powered down printer, took the sd card out, stuck it in my PC and not it's corrupted and can't reformat lol. Off to the store to buy a few more sd cards incase that happens again.
                        Duet Wifi
                        E3D v6 0.20mm
                        FSR autoleveling
                        • Saltlife716
                          Alright, All Fan and Endstop problems are solved. thanks guys!
                          Duet Wifi
                          E3D v6 0.20mm
                          FSR autoleveling
                          • Ivogrundel
                            Ivogrundel @Saltlife716 last edited by Ivogrundel
                            @saltlife716 do you have got a picture on how you solved this? I mean the fan’s because I have the same problem.
