    Panel Due 7 from Duet 2 WIFI to Duet 3 mini5+
    • handyandyundefined
      handyandy
      Hi, I replacing my Duet2 WIFI board with a Duet 3 mini 5+ board. Previously my Panel Due 7 connected with a 4 wire connection. I don't want to use the ribbon cable method. I can't see anywhere on the new board for this to work Can anyone help please?
      handyandyundefined 1 Reply Last reply Reply Quote 0
        handyandy @handyandy
        @handyandy Hi, I have just spotted the solution to this at the end of the 'Getting Started' document. I should RTFM more!
