    IDEX HOMING ISSUES
    Firmware installation
    661
    • Rolluxundefined
      Rollux @Rollux
      Home All.mp4
      Proschi3Dundefined 1 Reply Last reply Reply Quote 0
      • Proschi3Dundefined
        Proschi3D @Rollux
        @Rollux
        It looks to me like the mesh bed compensation is going on a total roller coaster ride. Can you disable it before homing
        Love my Duet 3 Mini.
        https://www.instagram.com/proschi3d
        https://youtube.com/@proschi3d
        https://www.proschi3d.de
          Proschi3D @Proschi3D
          @Proschi78 said in IDEX HOMING ISSUES:
          @Rollux
          try this as homeall
          Can you take over the code with copy paste for homeall that I posted here?
          M561
          G91
          G1 H2 Z5 F6000               ; raise head 4mm to keep it clear of the bed
          G1 H1 X-450 Y-450 U0 F3000 ; coarse home X, Y and U
          G1 X5 Y5 U-5 F3000           ; move 4mm away from the homing switches
          G1 H1 X-400 Y-430 U0 F600      ; fine home X, Y and U
          G90 ; absolute positioning
          ; Now home Z using the Z probe
          G1 X243 Y200 F3000  ; move to bed centre for probing
          G30 ; probe the bed and set Z height
          G1 x-450 y-430 U0 F3000
          G29 S1
          Rolluxundefined 2 Replies Last reply Reply Quote 0
          • Rolluxundefined
            Rollux @Proschi3D
            @Proschi78 Will give this a try tomorrow, unable to connect to the printer at the moment as having internet/router issues and pc vs printer location makes ethernet connection not viable.
            • Rolluxundefined
              Rollux @Proschi3D
              @Proschi78
              Tried the above and the movement behaviour became consistently erratic. Not sure as to why. Reverted back to the below and seems to be have "settled" to a somewhat normal behaviour. Potentially might reset the mbh6c and expansion board back to square one. Potentially the firmware updates may have left some things stuck which shouldnt be the case but never know as all the boards were still on 3.2 beta firmware when started up this time round.
              M561
              G91                               ; relative positioning
              G1 H2 Z5 F6000                    ; lift Z relative to current position
              G1 H1 X-450 F5000                 ; move quickly to X Y and U axis endstops and stop there (first pass)
              G1 H1 U0 F5000
              G1 H1 Y-450 F5000
              G1 H2 X5 F6000                    ; go back a few mm
              G1 H2 U-5 F6000
              G1 H2 Y5 F6000
              G1 H1 X-450 F360                 ; move slowly to X Y and U axis endstops once more (second pass)
              G1 H1 U0 F360
              G1 H1 Y-450 F360
              G1 F6000 X243 Y200
              G30
              G29 S1                            ; this loads the contents of /sys/heightmap.csv
