    Caution when fitting a mount or adaptor to the 3 holes in the SE
    • DjDemonD
      DjDemonD last edited by
      So I redesigned Lykle/Zesty's Nimble holder for the smart effector. Unfortunately the early prototype version I was using did not quite have enough clearance for the large nut that holds the hotend in the z dimension. As such to get the adaptor to sit level, I had to tighten the bolts a little too much, this stiffens the smarteffector PCb, meaning it triggers less well.
      So just a note of caution ensure the mount sits passively with a little tolerance to ensure it does not make your SE perform less well than it should.
      Lykle's verison redesigned to avoid this problem - https://www.thingiverse.com/thing:2719039
      Mine with nut trap for large nut - https://www.thingiverse.com/thing:2551302
      www.precisionpiezo.co.uk
      • Dougal1957
        Dougal1957 last edited by
        Lykle had already redesigned that mount to raise the platform by 1mm due to this
        • DjDemonD
          Yes ignore this thread in fact I might delete it. 🙂
          • DjDemonD
            Am now trying this one instead: https://www.thingiverse.com/thing:2740387
            As having the nut trap for the large nut is really useful.
            EDIT - seems to work okay. Sensitivity is normal.
