    RepRapFirmware Configuration Tool results printout
    • handyandyundefined
      handyandy
      Hi, Just a quick one.
      Is it possible to get a full printout of the results from the Reprap configuration tool?
      If I click on the open file and select print I only get parts of it printed. I really want a good print with all the alterations I've made.
      I presume this because its a webpage not a text file as such.
      Is this possible?
      • chrishammundefined
        chrishamm administrators @handyandy
        @handyandy In the configtool you can click on "Load Config Template" and select sys/configtool.json, that should restore your inputs. Is that what you are looking for?
        Duet software engineer
        handyandyundefined 1 Reply Last reply Reply Quote 0
          handyandy @chrishamm
          @chrishamm I was actually looking to be able to have a hard copy (printout)
            @handyandy Ctrl+P or Menu -> Print on the config page would do the trick then. You can save everything to a PDF file as well using the same option.
              @chrishamm thanks I tried that but the printout does not show all the details in the original web page. I could not find the PDF option anywhere. Where is it?
