    CAnnot get plugin to build with v3.5-dev
    Plugins for DWC and DSF
    • stuartofmtundefined
      stuartofmt
      When I try to build a plugin with 3.5-dev, I get an error ' ERROR No Webpack chunks have be added to the ZIP archive.`. Any idea why? I can build in 3.4.6 OK.
      This is on Win11.
      There is no zip file is created.
      When I first build the dev environment, npm run serve runs without errors.
      After trying to build the plugin: If I try npm run serve again, I get the following error. It seems that the act of trying to build a plugin changes something ...
      C:\Users\stuar\Github\DWCv3.5-dev>npm run serve
      > duetwebcontrol@3.5.2-rc.1 serve
      > vue-cli-service serve
       INFO  Starting development server...
       ERROR  AssertionError [ERR_ASSERTION]: Missing entry point (index.js, index.ts, dwc-src/index.js, dwc-src/index.ts, src/index.js, src/index.ts) in plugin DuetLapse3
          at C:\Users\stuar\Github\DWCv3.5-dev\webpack\lib\auto-imports-plugin.js:54:17
          at Hook.eval [as call] (eval at create (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\node_modules\tapable\lib\HookCodeFactory.js:19:10), <anonymous>:9:1)
          at Hook.CALL_DELEGATE [as _call] (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\node_modules\tapable\lib\Hook.js:14:14)
          at createCompiler (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\lib\webpack.js:86:28)
          at create (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\lib\webpack.js:145:16)
          at webpack (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\lib\webpack.js:173:32)
          at f (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\webpack\lib\index.js:73:16)
          at serve (C:\Users\stuar\Github\DWCv3.5-dev\node_modules\@vue\cli-service\lib\commands\serve.js:185:22)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      Full output from plugin build attempt below
      C:\Users\stuar\Github\DWCv3.5-dev>cmd.exe /c npm run build-plugin "../DuetLapse3/pluginv3.5-dev"
      > duetwebcontrol@3.5.2-rc.1 build-plugin
      > node scripts/build-plugin.js ../DuetLapse3/pluginv3.5-dev
      All browser targets in the browserslist configuration have supported ES module.
      Therefore we don't build two separate bundles for differential loading.
      /  Building for production...[BABEL] Note: The code generator has deoptimised the styling of C:\Users\stuar\Github\DWCv3.5-dev\node_modules\vuetify\dist\vuetify.js as it exceeds the max of 500KB.
      -  Building for production...
       DONE  Compiled successfully in 236835ms        1:56:47 PM
        File                                        Size                                Gzipped
        dist\js\monaco-editor.54de9d18.js           4748.92 KiB                         1058.10 KiB
        dist\js\app.fc942cc4.js                     3764.19 KiB                         816.44 KiB
        dist\js\GCodeViewer.2c2d2e4a.js             2699.53 KiB                         590.23 KiB
        dist\js\HeightMap.0a7868ce.js               1464.97 KiB                         316.40 KiB
        dist\js\OnScreenKeyboard.08821710.js        106.99 KiB                          33.03 KiB
        dist\js\InputShaping.3edf6046.js            81.09 KiB                           17.29 KiB
        dist\js\ObjectModelBrowser.b7c78d60.js      25.50 KiB                           6.78 KiB
        dist\workbox-6567b62a.js                    14.11 KiB                           4.93 KiB
        dist\js\monaco-json-worker.1cd76b1b.js      2.80 KiB                            1.01 KiB
        dist\js\monaco-worker.6d781179.js           2.79 KiB                            1.00 KiB
        dist\service-worker.js                      2.16 KiB                            1.01 KiB
        dist\css\app.1e72278e.css                   768.96 KiB                          107.11 KiB
        dist\css\monaco-editor.bda37737.css         112.91 KiB                          18.12 KiB
        dist\css\GCodeViewer.5c28e225.css           14.26 KiB                           2.96 KiB
        dist\css\ObjectModelBrowser.562feac3.css    6.60 KiB                            1.24 KiB
        dist\css\OnScreenKeyboard.425af7fa.css      3.53 KiB                            1.13 KiB
        dist\css\HeightMap.6241cfd5.css             0.49 KiB                            0.24 KiB
        dist\css\InputShaping.bd3578ab.css          0.44 KiB                            0.24 KiB
        Images and other types of assets omitted.
        Build at: 2024-06-10T19:56:48.845Z - Hash: 030dae31db75d394 - Time: 236835ms
       DONE  Build complete. The dist directory is ready to be deployed.
       INFO  Check out deployment instructions at https://cli.vuejs.org/guide/deployment.html
       ERROR  No Webpack chunks have be added to the ZIP archive. Make sure it is imported by src/plugins/index.ts
      • chrishammundefined
        chrishamm administrators @stuartofmt
        @stuartofmt Works on my machine ¯_(ツ)_/¯
        DuetWebControl (v3.5-dev)> npm run build-plugin /tmp/DuetLapse3/plugin\ 3.5.0-rc.1
         DONE  Compiled successfully in 38972ms        10:42:09 AM
          File                                        Size        Gzipped
          dist/js/monaco-editor.54de9d18.js           4748.92 KiB                                                             1059.14 KiB
          dist/js/app.7fe0f815.js                     3756.81 KiB                                                             816.91 KiB
          dist/js/GCodeViewer.3503fc35.js             2699.13 KiB                                                             590.56 KiB
          dist/js/HeightMap.e9be5939.js               1464.89 KiB                                                             316.49 KiB
          dist/js/OnScreenKeyboard.4868047e.js        106.91 KiB                                                              33.02 KiB
          dist/js/InputShaping.29011313.js            80.69 KiB                                                               17.24 KiB
          dist/js/ObjectModelBrowser.5cc7623a.js      25.42 KiB                                                               6.81 KiB
          dist/workbox-6567b62a.js                    14.11 KiB                                                               4.93 KiB
          dist/js/DuetLapse3.42bb1c87.js              5.57 KiB        1.64 KiB
          dist/js/monaco-json-worker.1cd76b1b.js      2.80 KiB        1.01 KiB
          dist/js/monaco-worker.6d781179.js           2.79 KiB        1.00 KiB
          dist/service-worker.js                      2.32 KiB        1.07 KiB
          dist/css/app.ef12892b.css                   768.96 KiB                                                              107.11 KiB
          dist/css/monaco-editor.bda37737.css         112.91 KiB                                                              18.13 KiB
          dist/css/GCodeViewer.eeec8def.css           14.26 KiB                                                               2.96 KiB
          dist/css/ObjectModelBrowser.562feac3.css    6.60 KiB        1.24 KiB
          dist/css/OnScreenKeyboard.df360b5d.css      3.53 KiB        1.13 KiB
          dist/css/HeightMap.a997084c.css             0.49 KiB        0.24 KiB
          dist/css/InputShaping.3cce14a7.css          0.44 KiB        0.24 KiB
          dist/css/DuetLapse3.6e428bb0.css            0.15 KiB        0.12 KiB
          Build at: 2024-06-11T08:42:09.619Z - Hash: 4b71838674ac59bd - Time: 38972ms
         DONE  Plugin ZIP file written to dist/DuetLapse3-5.3.3.zip
        Duet software engineer
        stuartofmtundefined 1 Reply Last reply Reply Quote 0
          stuartofmt @chrishamm
          @chrishamm
          I'm cannot figure out what's actually going on ...
          This call .run("build", {}, ["build"]) (near the start of the build-plugin.js script) does not create files for the plugin in the dist/css/ or dist/js/ directory. This, obviously causes a downstream failure, specifically no zip file being created.
          The script goes through the "Building for production" dance BUT does not report any errors.
          Anyway to modify the script so that it reports errors ?
            stuartofmt @stuartofmt
            @chrishamm
            Figured it out. I omitted src/index.js for the plugin (possibly during a copy / paste) . The build thought it had suceeded but it failed silently.
            • dc42undefined dc42 marked this topic as a question
              @chrishamm
              I took the liberty of adding some additional checks / logging to build-plugin.js. Warns if the plugin src/index.js file is missing. Hopefully helpful:
              build-plugin.js
