Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2
What version is/was your DWC running?
Can you re-download 3.5.2 zip?
@Phaedrux said in Can't connect Duet 3 6HC v1.0 after updating to RRF 3.5.2:
Now it's 3.5 (it was 3.4.5 on the first brick but it was 3.5 on the second)
I have only the uncompressed version, but I don't see how it can be useful, since it contains the same file I flashed with BOSSA.
You can only upload the zip file itself. DWC takes care of the rest. If you're uploading anything else that's probably the problem.
I always uploaded the zip.
I used the single uncompressed file only when flashing with BOSSA. -
What browser are you using?
@Phaedrux Web interface via Orca Slicer
I'm not very familiar with Orca slicer. How does that work? It has a built in browser?
What browser are you using to upload the firmware zip file?
So it seems.
I told you: Web interface via Orca Slicer
Can you try chrome?
Can you try chrome?
I could, but I don't want to risk another brick + reflash, sorry...
If I'll remember I'll do it in the next update.
