    Building 3.5(.2) and CoreTypes.h not found
    Beta Firmware
    384
    • GeneRisiundefined
      GeneRisi
      For the default selection of "SAME70_RTOS" I am getting an error message
      09:58:25 **** Build of configuration SAME70_RTOS for project CANlib-3.5-dev ****
      make all
      Building file: ../src/CanMessageBuffer.cpp
      Invoking: Cross G++ Compiler
      arm-none-eabi-g++ -std=gnu++17 -D__SAME70Q20B__ -DRTOS -O2 -Wall -c -mcpu=cortex-m7 -mthumb -fno-math-errno -mfpu=fpv5-d16 -mfloat-abi=hard -mfp16-format=ieee -mno-unaligned-access -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -fsingle-precision-constant "-Wa,-ahl=CanMessageBuffer.s" -MMD -MP -MF"src/CanMessageBuffer.d" -MT"src/CanMessageBuffer.o" -o "src/CanMessageBuffer.o" "../src/CanMessageBuffer.cpp"
      In file included from ../src/CanMessageBuffer.h:15,
                       from ../src/CanMessageBuffer.cpp:8:
      ../src/CanId.h:12:10: fatal error: CoreTypes.h: No such file or directory
         12 | #include <CoreTypes.h>          // for CanAddress
      compilation terminated.
      make: *** [src/CanMessageBuffer.o] Error 1
      "make all" terminated with exit code 2. Build might be incomplete.
      09:58:26 Build Failed. 2 errors, 0 warnings. (took 141ms)
      I am building for a Duet2 system so I don't know if I even need CANlib.
      How do I fix the error?
      Thanks!
      Gene
      • chrishammundefined
        chrishamm administrators @GeneRisi
        @GeneRisi If you want to build for Duet 2 then you need to build the Duet 2 configuration (Duet2). Did you follow these instructions for 3.5? https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware
        Duet software engineer
        GeneRisiundefined 1 Reply Last reply Reply Quote 0
        • GeneRisiundefined
          GeneRisi @chrishamm
          @chrishamm I still get the missing include file error even when using SAME4E_RTOS for the CANlib build (which I guess makes sense). Do you know where the include file should be located?
          Gere
          11:04:37 **** Incremental Build of configuration SAM4E_RTOS for project CANlib-3.5-dev ****
          make all
          arm-none-eabi-g++ -std=gnu++17 -D__SAM4E8E__ -DRTOS -Os -Wall -c -mcpu=cortex-m4 -mthumb -fno-math-errno -mfpu=fpv4-sp-d16 -mfloat-abi=hard -mfp16-format=ieee -ffunction-sections -fdata-sections -fno-threadsafe-statics -fno-rtti -fno-exceptions -nostdlib -Wundef -Wdouble-promotion -Werror=return-type -fsingle-precision-constant "-Wa,-ahl=CanMessageBuffer.s" -MMD -MP -MF"src/CanMessageBuffer.d" -MT"src/CanMessageBuffer.o" -o "src/CanMessageBuffer.o" "../src/CanMessageBuffer.cpp"
          11:04:37 Build Failed. 2 errors, 0 warnings. (took 141ms)
          GeneRisiundefined chrishammundefined 2 Replies Last reply Reply Quote 0
          • GeneRisiundefined
            GeneRisi @GeneRisi
            @chrishamm Somehow I got the right config file when building 3.5.1 but don't have it for 3.5.2. What is it called? I am not finding it with a quick scan.
            Thanks, Chris!
              @GeneRisi Make sure you have the right CoreN2G branch checked out:
              > find ./ -name CoreTypes.h
              ./CoreN2G/src/CoreTypes.h
              Also run a "Refresh" action via right-click on the different projects (in particular RepRapFirmware) after changing the source files. That sometimes fixes build errors for me.
              • GeneRisiundefined
                GeneRisi @chrishamm
                I was forced to re-install Eclipse. After loading the individual projects, my screen looks like this. I no longer have the Hammer drop down menu. What am I missing?
                Gene
                  @GeneRisi I'm sorry but I don't have OS X so I can't say much about Eclipse on it. I can right-click the RepRapFirmware project and choose Build Project or set the active config via Build Configurations -> Set Active.
                  • GeneRisiundefined
                    GeneRisi @chrishamm
                    @chrishamm I discovered the solution. After loading all of the projects, then do a full clean and then quit Eclipse. Restart Eclipse and now the board build options should be available under the Hammer icon.
