Can no longer use the manual extrude Buttons (greyed out)
As Per the Title
Turned on this printer for the first time in about a week, and after heating the hot end the extrude/retract buttons normally come alive after a certain temp now they don't, haven't changed firmware or config.g it was fine last week.....
Board Duet-2 wifi
Duet Web Control 3.5.2
Product Short Name Version
Duet 2 WiFi 2WiFi 3.5.2
Duet WiFi Server n/a 2.1.0
Duet Web Control DWC 3.5.2Added config.g but 100% NOTHING Has been changed since it worked last week
; General preferences ;-------------------------------------------------------------------------------------------------------------- ; M552 S1 G90 ; Use absolute coordinate moves M83 ; Relative extruder moves M550 P"300mm Titan Aero" ; Printer name M564 S0 H0 ; Allow movement before homing ; ;-------------------------------------------------------------------------------------------------------------- ; Network ;-------------------------------------------------------------------------------------------------------------- ; M552 S1 ; Enable network M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; ;-------------------------------------------------------------------------------------------------------------- ; Drives ;-------------------------------------------------------------------------------------------------------------- ; M669 K0 ; Kinematics Type is set to "Cartesian" M671 X-25:255 Y0:0 S10 ; Z axis pivot points M569 P0 S0 ; Drive 0 (X) goes forwards M569 P1 S1 ; Drive 1 (Y) goes backwards M569 P2 S1 ; Drive 2 (Z1 Left) goes forwards M569 P3 S0 ; Drive 3 (Extruder) goes forwards M569 P4 S0 ; Drive 4 (Z2 Right) goes forwards M584 X0 Y1 Z2:4 E3 ; Drive mapping M350 X32 Y32 Z16 E16 I1 ; Micro-stepping with interpolation M92 X160.00 Y200.00 Z400.00 E465 ; Steps per mm M566 X900.00 Y900.00 Z900.00 E300.00 ; Mximum instantaneous speed changes (mm/min) M203 X9000.00 Y9000.00 Z1800.00 E6000.00 ; Maximum speeds (mm/min) M201 X800.00 Y800.00 Z500.00 E5000.00 ; Accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I50 ; Motor currents (mA) & motor idle factor % M84 S30 ; Idle timeout ; ;-------------------------------------------------------------------------------------------------------------- ; Axis Limits ;-------------------------------------------------------------------------------------------------------------- ; M208 X-8 Y-30 Z-2 S1 ; Axes min M208 X300 Y300 Z350 S0 ; Axes max ; ;-------------------------------------------------------------------------------------------------------------- ; Endstops ;-------------------------------------------------------------------------------------------------------------- ; M574 X1 S1 P"xstop" ; The X axis endstop is at the low end, & mapped to the "xstop" pin M574 Y1 S1 P"ystop" ; The Y axis endstop is at the low end, & mapped to the "ystop" pin M574 Z1 S2 ; z-probe endstop at the low end on Z ; ;-------------------------------------------------------------------------------------------------------------- ; Z-Probe (BL-Touch) ;-------------------------------------------------------------------------------------------------------------- ; M950 S0 C"exp.heater3" ; The servo pin is "heater-3" for the BLTouch M558 P9 C"zprobe.in" H10 R0.3 T15000 F15000:240 ; The Z probe type signal pin is "zprobe in", the dive heigt is 10mm + speed settings G31 P500 X-24 Y-38 Z2.378 ; Toolhead Offsets, the Z probe trigger value, offset and trigger height, (make the numbers SMALLER to move the nozzle AWAY from the bed) M557 X30:260 Y50:280 P12 ; Define a mesh grid ; ;-------------------------------------------------------------------------------------------------------------- ; Z Stop ;-------------------------------------------------------------------------------------------------------------- ; M558 K1 P8 C"!zstop" H10 R0.3 F6000 T10000 A3 S0.06 ; The Z End-Stop is type 8 (A Simple Switch) & is mappped/connected to the zstop port on the mainboard G31 K1 P500 X0 Y0 Z0 ; Z End-Stop X, Y & Z offsets ; ;-------------------------------------------------------------------------------------------------------------- ; Bed Heater ;-------------------------------------------------------------------------------------------------------------- ; M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; The Bed sensor "sensor 0" is a thermistor M950 H0 C"bedheat" T0 ; The bed heater is configured to the "bedheat"and mapped to sensor 0 M307 H0 R0.881 K0.405:0.000 D10.62 E1.35 S1.00 B0 ; Heater tuning results M140 H0 ; The bed heater is mapped to be "H0" M143 H0 S120 ; The temperature limit for "H0" is set to 120C ; ;-------------------------------------------------------------------------------------------------------------- ; Hot-End Heater ;-------------------------------------------------------------------------------------------------------------- ; M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; The hot-end sensor "sensor 1" is a thermistor M950 H1 C"e0heat" T1 ; the hot-end is configured to "e0heat" mapped to sensor 1 M307 H1 R2.563 K0.367:0.000 D3.24 E1.35 S1.00 B0 V24.1 ; Heater tuning results M143 H1 S310 ; The temperature limit for "H1" is 310C ; ;-------------------------------------------------------------------------------------------------------------- ; Fans ;-------------------------------------------------------------------------------------------------------------- ; M950 F0 C"fan0" ; The art-cooling" fan is "fan1" & it's frequency is set to 500 M106 P0 S0 ; The start value of fan0 is ZERO ; ;-------------------------------------------------------------------------------------------------------------- ; Tools ;-------------------------------------------------------------------------------------------------------------- ; M563 P0 S"Titan Aero" D0 H1 F0 ; Tool 0's definitions G10 P0 X0 Y0 Z0 ; Tool 0's axis offsets G10 P0 R0 S0 ; The tool "tool 0" is set to active and it's standby temperatures is set to 0C
Output From M122
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet WiFi 1.0 or 1.01 Board ID: 08DAM-999TL-MQ4S8-6J9D8-3SJ6M-15BZW Used output buffers: 6 of 26 (22 max) === RTOS === Static ram: 23384 Dynamic ram: 73056 of which 12 recycled Never used RAM 13764, free system stack 136 words Tasks: NETWORK(2,nWait 6,13.8%,218) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,310) MAIN(1,running,86.1%,742) IDLE(0,ready,0.0%,29), total 100.0% Owned mutexes: WiFi(NETWORK) === Platform === Last reset 01:33:27 ago, cause: software Last software reset at 2024-06-22 16:59, reason: User, Gcodes spinning, available RAM 13912, slot 1 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a Error status: 0x00 MCU temperature: min 46.0, current 48.9, max 50.4 Supply voltage: min 23.8, current 24.2, max 24.5, under voltage events: 1, over voltage events: 0, power good: yes Heap OK, handles allocated/used 99/0, heap memory allocated/used/recyclable 2048/16/16, gc cycles 0 Events: 0 queued, 0 completed Driver 0: standstill, SG min 0 Driver 1: standstill, SG min 0 Driver 2: standstill, SG min 0 Driver 3: standstill, SG min n/a Driver 4: standstill, SG min 0 Driver 5: Driver 6: Driver 7: Driver 8: Driver 9: Driver 10: Driver 11: Date/time: 2024-06-22 18:39:00 Cache data hit count 4294967295 Slowest loop: 22.62ms; fastest: 0.18ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 9.9ms, write time 5.6ms, max retries 0 === Move === DMs created 83, segments created 3, maxWait 481601ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00 no step interrupt scheduled Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0 === DDARing 0 === Scheduled moves 13, completed 13, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters 0 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.2 === GCodes === Movement locks held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 LCD is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Q0 segments left 0 Code queue 0 is empty === Network === Slowest loop: 34.77ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) HTTP sessions: 1 of 8 === WiFi === Interface state: active Module is connected to access point Failed messages: pending 0, notrdy 0, noresp 0 Firmware version 2.1.0 MAC address 5c:cf:7f:2c:29:2d Module reset reason: Turned on by main processor, Vcc 3.39, flash size 4194304, free heap 42884 WiFi IP address 192.168.0.103 Signal strength -49dBm, channel 6, mode 802.11n, reconnections 1 Clock register 00002002 Socket states: 0 5 0 0 0 0 0 0
@Mr-Crispin add "T0" on its own line at the end of your config
@jay_s_uk said in Can no longer use the manual extrude Buttons (greyed out):
ok (that worked) Thank You
But why is/was that now needed when it wasn't needed previously ? Not trying to be funny, im just trying to understand
@Mr-Crispin you may have been activating the tool by clicking tool0 in DWC before using it. Or your slicer may be selecting the tool when printing. But ultimately a tool needs to be active before you can control the extruder motor associated with it
