    Where can I find PWM 3 pin 4010 fans
    • gnydickundefined
      gnydick
      I can't find any. I have ones with only tach and they squeal non-stop when they're not running.
      I want to be able to monitor fan speed for both cold section and print cooling. I'm using toolboards and I can't find a solution since there aren't enough 4 pin outputs. I can only find 4 wire pwm 4010 fans.
      turtlecrawlerundefined 1 Reply Last reply Reply Quote 0
      • turtlecrawlerundefined
        turtlecrawler @gnydick
        @gnydick I bought a 5 pack off amazon, Winsin branded. They seem to work fine, but I will be replacing them with a Sunon MF40100V1-1000U-F99 from Digikey. I needed some more Molex connectors, and checked Digikey for some better 4010 3 wire fans.
        gnydickundefined 1 Reply Last reply Reply Quote 0
        • gnydickundefined
          gnydick @turtlecrawler
          @turtlecrawler let me know if yours squeal while idle.
