Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you have been placed in read-only mode.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
In DWC if you use M141 it will auto set this for Chamber Is there an option to set "Dry Box temperature M14?
If you have only one chamber heater defined (which you have named "Dry Box") then M141 S60 would set the active temp to 60 degrees and make it active.
M141 S60
