    M587 :No Wi-Fi interface available
    Duet Web Control
    256
    • Ironman777undefined
      Ironman777
      So I decided to fire up my printer after a while, everything works perfectly but only allows me to connect via Ethernet cable - No Wi-Fi interface available. I just updated the firmware to the latest version my board is a duet3 6HC
      • gloomyandyundefined
        gloomyandy @Ironman777
        @Ironman777 Was the WiFi interface working before the update? What version of the firmware did you have installed when it was working? Did you update the WiFi module firmware as part of the update? Posting your config.g file and the output from M122 will probably help folks work out what is happening.
        Ironman777undefined 1 Reply Last reply Reply Quote 0
          Ironman777 @gloomyandy
          @gloomyandy It was running 3.1.2 and it was not working before the update. I believe everything was updated
          Here is my config.
          ; generated by RepRapFirmware Configuration Tool v3.1.10 on Fri Dec 11 2020 20:02:21 GMT-0800 (Pacific Standard Time)
          M550 P"My Printer" ; set printer name
          M669 K1 ; select CoreXY mode
          M552 P192.168.0.147 S1 ; enable network and acquire dynamic address via DHCP
          M586 P0 S1 ; enable HTTP
          M586 P1 S0 ; disable FTP
          M586 P2 S0 ; disable Telnet
          M569 P0.5 S1 ; physical drive 0.5 goes forwards
          M569 P0.1 S1 ; physical drive 0.1 goes forwards
          M569 P0.0 S0 ; physical drive 0.0 goes backwards
          M569 P0.2 S0 ; physical drive 0.2 goes backwards
          M584 X0.5 Y0.1 Z0.0 E0.2 ; set drive mapping
          M350 X256 Y256 Z256 I0 ; configure microstepping without interpolation
          M350 E16 I1 ; configure microstepping with interpolation
          M92 X1280.00 Y1280.00 Z6666.00 E415.00 ; set steps per mm
          M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
          M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
          M906 X2000 Y2000 Z2000 E1800 I30 ; set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M208 X590 Y590 Z590 S0 ; set axis maxima
          M574 X1 S1 P"!io1.in" ; configure active-high endstop for low end on X via pin !io1.in
          M574 Y1 S1 P"!io2.in" ; configure active-high endstop for low end on Y via pin !io2.in
          M574 Z1 S1 P"!io3.in" ; configure active-high endstop for low end on Z via pin !io3.in
          M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
          M557 X15:215 Y15:195 S20 ; define mesh grid
          M140 H-1 ; disable heated bed (overrides default heater mapping)
          M308 S0 P"TEMP_0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin TEMP_0
          M950 H0 C"OUT0" T0 ; create nozzle heater output on OUT0 and map it to sensor 0
          M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H0 S280 ; set temperature limit for heater 0 to 280C
          M950 F0 C"out4" Q500 ; create fan 0 on pin out4 and set its frequency
          M563 P0 D0 H0 F0 ; define tool 0
          M575 P1 B57600 S1 ; enable PanelDue
          T0
            @Ironman777 This may seem like a silly question but do you have a WiFi module installed (It is optional and I think only available on recent versions of the 6HC)? Your config.g file does not seem to have any commands to enable a WiFi module, what are you doing to test to see if the WiFi is working?
              Ironman777
              MY M122
              M587
              Error: M587: No WiFi interface available
              ok
              M589
              Error: M589: No WiFi interface available
              ok
              M122
              RepRapFirmware for Duet 3 MB6HC version 3.5.2 (2024-06-11 17:13:58) running on Duet 3 MB6HC v1.01 (standalone mode)
              Board ID: 08DJM-956BA-NA3TJ-6JTD8-3SN6K-1AAQU
              Used output buffers: 1 of 40 (36 max)
              Static ram: 155360
              Dynamic ram: 120280 of which 36 recycled
              Never used RAM 67124, free system stack 116 words
              Tasks: NETWORK(1,ready,34.6%,179) ETHERNET(5,nWait 7,0.2%,315) HEAT(3,nWait 1,0.0%,321) Move(4,nWait 6,0.7%,217) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,10.2%,53) MAIN(1,running,54.2%,103) IDLE(0,ready,0.0%,29), total 100.0%
              Owned mutexes: USB(MAIN)
              Last reset 00:27:02 ago, cause: power up
              Last software reset details not available
              Error status: 0x00
              Aux0 errors 0,0,0
              MCU temperature: min 31.5, current 39.7, max 41.5
              Supply voltage: min 26.2, current 26.4, max 26.7, under voltage events: 0, over voltage events: 0, power good: yes
              12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
              Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/36/24, gc cycles 0
              Events: 0 queued, 0 completed
              Driver 0: standstill, SG min 0, mspos 103, reads 60474, writes 29 timeouts 0
              Driver 1: standstill, SG min 0, mspos 9, reads 60475, writes 29 timeouts 0
              Driver 2: ok, SG min 0, mspos 85, reads 60479, writes 25 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 8, reads 60493, writes 11 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 8, reads 60493, writes 11 timeouts 0
              Driver 5: ok, SG min 0, mspos 427, reads 60476, writes 29 timeouts 0
              Date/time: 2024-06-30 15:05:34
              Slowest loop: 223.30ms; fastest: 0.07ms
              === Storage ===
              Free file entries: 19
              SD card 0 detected, interface speed: 25.0MBytes/sec
              SD card longest read time 5.9ms, write time 64.4ms, max retries 0
              DMs created 125, segments created 14, maxWait 262907ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
              next step interrupt due in 23 ticks, disabled
              Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
              === DDARing 0 ===
              Scheduled moves 3540, completed 3537, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 45], CDDA state 3
              === DDARing 1 ===
              Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
              Heater 0 is on, I-accum = 0.4
              HTTP is idle in state(s) 0
              Telnet is idle in state(s) 0
              File is doing "G1 X221.397 Y242.780 E13.3054" in state(s) 0
              USB is ready with "M122" in state(s) 0
              Aux is idle in state(s) 0
              Trigger is idle in state(s) 0
              Queue is idle in state(s) 0
              LCD is idle in state(s) 0
              SBC is idle in state(s) 0
              Daemon is idle in state(s) 0
              Aux2 is idle in state(s) 0
              File2 is idle in state(s) 0
              Queue2 is idle in state(s) 0
              Q0 segments left 1, axes/extruders owned 0x80000007
              Code queue 0 is empty
              Code queue 1 is empty
              === CAN ===
              Messages queued 14600, received 0, lost 0, errs 7696823, boc 0
              Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 8113/0/0
              Tx timeouts 0,0,8112,0,0,6486 last cancelled message type 30 dest 127
              === Network ===
              Slowest loop: 526.96ms; fastest: 0.03ms
              Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
              HTTP sessions: 2 of 8
              = Ethernet =
              Interface state: active
              Error counts: 0 0 0 1 0 0
              Socket states: 2 2 2 2 2 0 0 0
              === Multicast handler ===
              Responder is inactive, messages received 0, responses 0
              ok
                @gloomyandy I do not see it either. However I used my printer for year straight WIFI connected and all I let it sit for about 4 years did not change a single thing fired it right up, no problems besides the WIFI. I also created a new RepRap config file to see if any paths would be missing due to lack of updates over the years, the codes looked exactly the same.
                  @Ironman777 Try running M552 I1 S1 and see if that enables the interface (try running M122 again after the M552 command and see if you have a WiFi section).
                    @gloomyandy M552 I1 S1
                    Error: M552: parameter 'I' too high
                    ok
                      droftarts administrators @Ironman777
                      @Ironman777 your 6HC doesn’t have WiFi on board. Maybe you were using an external Ethernet to WiFi adapter?
                        Ironman777
                        My mistake, after reviewing old pictures and videos I had the 3wifi and replaced it with 6HC right before I stopped 3D printing.
