    Error: M916: no resume file found
    Duet Web Control
    • Ironman777undefined
      Ironman777
      Any advice on- Error: M916: no resume file found. I have resurrect-prologue.g setup. 24V power supply with 10000 uf capacitor on VIN.
        droftarts administrators @Ironman777
        @Ironman777 See https://docs.duet3d.com/en/User_manual/Tuning/Resume
        If that doesn't help, please post your config.g, and send M122 in the DWC console and post the response. If you pause a print, is a sys/resurrect.g file created?
        Ironman777undefined 1 Reply Last reply Reply Quote 0
          Ironman777 @droftarts
          @droftarts so I was able to get the resume file to be created it just took some time for the capacitor to build a charge. Now the problem I have is with the offsets applied to make my print head square to the build plate the 0 position is off. When I press pause during a print it doesn’t return to limit switches it ends up coming up slightly short on X and Y.
