    HTML API /rr_connect?password=*** returns 404 Not Found
    Duet Web Control
    • qurtundefined
      qurt
      I do have a problem using the HTML API.
      I have one board that always reply with 404 Not Found error when i call curl http://<ip_machine1>/rr_connect?password=<password>
      curl : The remote server returned an error: (404) Not Found.
      At line:1 char:1
      + curl http://<ip_machine1>/rr_connect?password=<password>
          + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebExc
         eption
          + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
      both machines have HTTP enabled.
      M586 P0 S1                                                              ; enable HTTP
      M586 P1 S0                                                              ; disable FTP
      M586 P2 S0                                                              ; disable Telnet
      calling other machines with works fine curl http://<ip_machine2>/rr_connect?password=<password>
      StatusCode        : 200
      StatusDescription : OK
      Content           : {"apiLevel":1,"err":0,"isEmulated":true,"sessionTimeout":8000,"boardType":"duet3mb6xd100"}
      RawContent        : HTTP/1.1 200 OK
                          Content-Length: 90
                          Content-Type: application/json
                          Date: Tue, 23 Jul 2024 09:55:07 GMT
                          Server: Kestrel
                          {"apiLevel":1,"err":0,"isEmulated":true,"sessionTimeout":8000,"boardType":"...
      Forms             : {}
      Headers           : {[Content-Length, 90], [Content-Type, application/json], [Date, Tue, 23 Jul 2024 09:55:07 GMT],
                          [Server, Kestrel]}
      Images            : {}
      InputFields       : {}
      Links             : {}
      ParsedHtml        : mshtml.HTMLDocumentClass
      RawContentLength  : 90
      Is there any other config that might prevent that behavior. I am not aware of significant differences between both machine types.
      • chrishammundefined
        chrishamm administrators @qurt
        @qurt The affected SBC is outdated and does not support rr_ protocol emulation yet. Upgrade it using apt and then try again. See https://docs.duet3d.com/en/User_manual/Machine_configuration/DSF_RPi#installing-updates
        Also note that it would be better to use the native REST protocol in SBC mode unless you need to deal with boards in standalone mode, too. See https://github.com/Duet3D/DuetSoftwareFramework/wiki/REST-API for further information.
        Duet software engineer
