    End stops not working after upgrade to 1.19
    Firmware installation
    1218
    • RodF
      RodF last edited by
      The end stops are being triggered in Machine properties but not stopping the motors. And I am getting an error message on the IR Z probe "Insufficient axes homed for bed probing". I expect it is my bad, but cannot work it out. I tried changing the ends in M557 but no luck. Here are the home files.
      ; homeall.g
      ; called to home all axes
      ; generated by RepRapFirmware Configuration Tool on Sat Dec 17 2016 11:00:47 GMT+1300 (New Zealand Standard Time)
      ; Relative positioning
      G91
      ; Lift Z
      G1 Z5 F6000
      ; Move towards X and Y axis endstops (first pass)
      G1 X-305 Y-305 F1800 S1
      ; Go back a few mm
      G1 X5 Y5 F6000
      ; Move slowly to axis endstops once more (second pass)
      G1 X-305 Y-305 F360 S1
      ; Absolute positioning
      G90
      ; Go to first bed probe point and home the Z axis
      G1 X150 Y135 F6000
      G30
      ; Uncomment the following line to lift the nozzle after probing
      ;G1 Z5 F100
      ; homex.g
      ; called to home the X axis
      ; Lift Z relative to current position
      G91
      G1 Z5 F6000
      G90
      ; Move quickly to X axis endstop and stop there (first pass)
      G1 X-305 F1800 S1
      ; Go back a few mm
      G91
      G1 X5 F6000
      G90
      ; Move slowly to X axis endstop once more (second pass)
      G1 X-305 F360 S1
      ; Lower Z again
      G91
      G1 Z-5 F6000
      G90
      ; homey.g
      ; called to home the Y axis
      G91
      G1 Z5 F6000
      G90
      ; Move quickly to Y axis endstop and stop there (first pass)
      G1 Y-305 F1800 S1
      ; Go back a few mm
      G91
      G1 Y5 F6000
      G90
      G1 Y-305 F360 S1
      ; Lower Z again
      G91
      G1 Z-5 F6000
      G90
      ; homez.g
      ; called to home the Z axis
      ; Lift Z relatively to current position
      G91
      G1 Z5 F6000
      ; Back to absolute positioning
      G90
      G1 X20 Y30 F6000
      G30
      G91
      G1 Z5 F100
      G90
        Firmware 1.20 is current now. Please post your config.g file.
        • RodF
          RodF last edited by
          Awesome response as usual David. Will do the 1.2 upgrade. In the meantime here is config .g.
          ; Configuration file for Duet WiFi (firmware version 1.16)
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M667 S1 ; Select CoreXY mode
          M208 X300 Y300 Z350 S0 ; Set axis maxima
          M574 X1 Y1 Z0 S0 ; Define active low and unused microswitches
          M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
          G31 P500 X0 Y0 z1.76 ; Set Z probe trigger value, offset and trigger height
          M569 P0 S0 ; Drive 0 goes backwards
          M569 P1 S1 ; Drive 1 goes backwards
          M92 X160 Y160 Z3200 E422 ; Set steps per mm
          M203 X6000 Y6000 Z500 E1200 ; Set maximum speeds (mm/min)
          M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
          M906 X1700 Y1700 Z1700 E750 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M143 S300 ; Set maximum heater temperature to 260C
          ;M305 P0 T100000 B3950 R4700 ; Set thermistor + ADC parameters for heater 0
          M305 P1 X200 ; Set thermistor + ADC parameters for heater 1 and remap it to channel 200
          M563 P0 D0 H1 ; Define tool 0
          G10 P0 X0 Y0 ; Set tool 0 axis offsets
          M550 PMy printer ; Set machine name
          M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
          M501
            Thanks. I didn't spot anything wrong in the config file.
            Are they optical endstops? Those sometimes leak a little, often due to the carriage not completely blocking the slot, and if they don't have built-in pullup resistors then the external LED+resistor pullups in the endstop circuits may not be sufficient, resulting in no response or a slow response. In an earlier firmware version (1.18 AFAIR) I disabled the internal endstop pullups in the microprocessor to try to resolve a separate issue; but I've re-enabled them in firmware 1.20.
            • RodF
              RodF last edited by
              The end stops are mechanical except for the IR probe on Z. I have upgraded to 1.2. Now the end stops in Machine properties are hitting but the Z probe has stopped hitting however the red LED on the IR probe is still activating at the right distance from the bed.
              • RodF
                RodF last edited by
                I should of said end stops still not stopping X and Y axis and z still getting Insufficient axes homed for bed probing error
                • RodF
                  RodF last edited by
                  Also getting an error message when connecting on WiFi "Can't open 0:/sys/oem.json to read, error code 4"
                    @RodF:
                    That's normal, and you can ignore that message.
                    Please run M574 without parameters after a failed X or Y homing attempt and post the response here. You can reduce motor currents for now to avoid damage when homing an axis fails to stop.
                    What type of switch are they: simple 2-wire microswitches (in which case, why are you using the NO contacts instead of the NC ones), or the 3-wire Makerbot type?
                    • deckingman
                      deckingman last edited by
                      Just a thought but it's not this is it (from the upgrade notes for 1.19)….........
                      Quote
                      Important! If you use an IR Z probe or some other type that does not need to be deployed, delete the files sys/deployprobe and sys/retractprobe.g if they exist, because they are now called automatically. You can do this in the System Files Editor of the web interface.
                      ...........end of Quote
                      • RodF
                        RodF last edited by
                        Thanks for the input guys. The end stops are 3 wire Makerbot. I am also getting an error on the bed heater.
                        Error: Temperature reading fault on heater 0: unknown temperature sensor channel
                        M574 reports Endstop configuration: X:low end unknown type Y: low end unknown type Z: none,
                        • RodF
                          RodF last edited by
                          Decided I had nothing to lose and redid the configuration with the RRF configuration tool. This has sorted out all my problems. Thanks for your time David.
                            I'm sorry I was a little slow in responding. The M574 "unknown type" report was caused by a firmware bug, it should have said "active low switch". This will be fixed i release 1.20.1. The heater 0 problem was caused because you didn't have a M305 command for heater 0 in config.g.
                            • RodF
                              RodF last edited by
                              Thanks again. Happily printing now.
