    New beta firmware 1.20.1RC2 and DuetWiFiServer 1.20+1
    Firmware installation
    13
    68
    10.0k
    • burtoogleundefined
      burtoogle
      Appears to work as expected, testing PETG at 240C, 0.4mm v6, flex3drive extruder. Preliminary results indicate A=0.05, B=0.004 work well up to 3.5mm/S. From 4mm/S upwards, compensation not really effective which doesn't surprise me as I've never been able to reliably get much more than approx 6 mm^3/S out of the v6. Will continue to test but it's looking good so far.
        Thanks for the feedback. I have not tested whether increasing the spring tension on my Titan affects the amount of nonlinearity.
          burtoogle
          The flex3drive extruder doesn't appear to have any means of adjusting the "grip" - hasn't been a problem so far except for some TPU like stuff I have which is only 1.55 dia and so I have to add some packing to the over-centre lever otherwise the filament slips. The extruder works OK but it's a shame that it doesn't have any means of adjusting for filament diameters that aren't close to 1.75.
            burtoogle
            Done some prints with M592 active and they look very good. I believe the quality in terms of extrusion amounts has been improved. Here's a couple of images…
              burtoogle
              Discovered an interesting side effect of the non-linear extrusion - now that it doesn't underextrude (so much) at the higher extrusion rates, I found that a print using TPU like filament failed because the extrusion rate on a skin layer increased sufficiently to reach the throughput limit of the extruder/hotend combo. So a gcode file that had printed OK before, now doesn't print well. The solution was to reslice the part with a reduction in the speed at which the skin was being printed so that the throughput limit was no longer being reached.
              • BMMalundefined
                BMMal
                I did not get my machine to reproduce the slowdown issue I posted about in another thread. However, after updating to this firmware and printing for the last 30 minutes I checked the diagnostics and got the following:
                [[language]]
                SENDING:M122
                Used output buffers: 1 of 32 (16 max)
                RepRapFirmware for Duet WiFi version 1.21RC0+1 running on Duet WiFi 1.0 + DueX5
                Board ID: 08D6M-91AST-L23S4-7JTD8-3S86K-1PX1K
                Static ram used: 15448
                Dynamic ram used: 100464
                Recycled dynamic ram: 2872
                Stack ram used: 3584 current, 8472 maximum
                Never used ram: 3816
                Last reset 00:57:06 ago, cause: software
                Last software reset at 2018-01-22 15:05, reason: User, spinning module GCodes, available RAM 3536 bytes (slot 0)
                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                Error status: 8
                [ERROR] Error status: 8
                Free file entries: 8
                SD card longest block write time: 177.8ms
                MCU temperature: min 27.9, current 28.9, max 29.3
                Supply voltage: min 24.3, current 24.6, max 25.1, under voltage events: 0, over voltage events: 0
                Driver 0: ok, SG min/max 0/1023
                Driver 1: ok, SG min/max 0/1023
                Driver 2: standstill, SG min/max 0/624
                Driver 3: ok, SG min/max 0/237
                Driver 5: standstill, SG min/max 0/97
                Driver 6: standstill, SG min/max not available
                Driver 7: standstill, SG min/max not available
                Driver 8: standstill, SG min/max not available
                Driver 9: standstill, SG min/max not available
                Expansion motor(s) stall indication: yes
                Date/time: 2018-01-22 16:02:33
                Slowest main loop (seconds): 0.179090; fastest: 0.000046
                MaxReps: 4, StepErrors: 0, LaErrors: 0, FreeDm: 220, MinFreeDm 155, MaxWait: 4292717656ms, Underruns: 0, 0
                Scheduled moves: 2116, completed moves: 2109
                Bed compensation in use: none
                Heater 0 is on, I-accum = 0.0
                Heater 1 is on, I-accum = 0.1
                Segments left: 1
                Stack records: 4 allocated, 0 in use
                Movement lock held by null
                http is idle in state(s) 0
                telnet is idle in state(s) 0
                file is doing "G1 X318.756 Y289.891 E0.00223" in state(s) 0
                serial is ready with "M122" in state(s) 0
                aux is idle in state(s) 0
                daemon is idle in state(s) 0
                queue is idle in state(s) 0
                Code queue is empty.
                === Network ===
                Network state is running
                WiFi firmware version 1.20+1
                WiFi MAC address a0:20:a6:16:e6:c6
                WiFi Vcc 3.26, reset reason Turned on by main processor
                WiFi flash size 4194304, free heap 16832
                WiFi IP address 10.0.0.115
                WiFi signal strength -38dBm, reconnections 0, sleep mode modem
                HTTP sessions: 1 of 8
                Socket states:  0 0 0 0 0 0 0 0
                Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                Duet Ethernet - Most likely the most recent Edge firmware
                Duet X5
                7" Panel Due V2
                Cartesian, 4 Nozzles with Flex3Drives, Heated Chamber, Simple Switch Filament Sensing
                  Can you provide a link to your post in the other thread?
                  • BMMalundefined
                    BMMal
                    @dc42:
                    https://www.duet3d.com/forum/thread.php?id=4045#p36563
                    Duet X5
                    7" Panel Due V2
