    Build PanelDue Firmware Error
    PanelDue
    1
    1
    92
    • iDavidFengundefined
      iDavidFeng
      When I try build the firmware on ubuntu,Iget some error:
      Toolchain definition:
      CROSS_COMPILE prefix: arm-none-eabi-
      asm: arm-none-eabi-gcc
      😄 arm-none-eabi-gcc
      cxx: arm-none-eabi-g++
      ar: arm-none-eabi-ar
      objcopy: arm-none-eabi-objcopy
      objdump: arm-none-eabi-objdump
      C_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu17
      CXX_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu++17 -fno-threadsafe-statics -fno-rtti
      ASM_FLAGS: --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color
      LD_FLAGS:
      CMake Error at CMakeLists.txt:29 (file):
      file does not recognize sub-command REAL_PATH
      CMake Error at CMakeLists.txt:38 (file):
      Project Device: v3-5.0
      Project C_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu17
      Project CXX_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu++17 -fno-threadsafe-statics -fno-rtti
      Project ASM_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color
      Project LD_FLAGS: -Wl,--defsym,stack_size=0x1000 -T"" -Wl,-Map,paneldue.map -static --specs=nano.specs -Wl,--gc-sections -Wl,--fatal-warnings -Wl,--no-warn-rwx-segments
      librrf C_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu17
      librrf CXX_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color -std=gnu++17 -fno-threadsafe-statics -fno-rtti
      librrf ASM_FLAGS: -O2 -g -DNDEBUG -DBOARD=USER_BOARD -DARM_MATH_CM4=true -D__SAM4S4B__ -mcpu=cortex-m4 -mthumb -DSCREEN_50=1 -DDEVICE=v3-5.0 --param max-inline-insns-single=500 -mlong-calls -ffunction-sections -fdata-sections -fno-exceptions -fsingle-precision-constant -Wall -Wextra -Wundef -Wdouble-promotion -Wno-expansion-to-defined -fdiagnostics-color
      -- Configuring incomplete, errors occurred!
      See also "/mnt/hgfs/vmware/PanelDueFirmware/build/CMakeFiles/CMakeOutput.log".
      See also "/mnt/hgfs/vmware/PanelDueFirmware/build/CMakeFiles/CMakeError.log".
      And the log is blow:
      CMakeOutput.log:
      The target system is: Generic - - cortex-m4
      The host system is: Linux - 5.15.0-107-generic - x86_64
      Compiling the C compiler identification source file "CMakeCCompilerId.c" succeeded.
      Compiler: /opt/gcc-arm-none-eabi/bin/arm-none-eabi-gcc
      Build flags: --param;max-inline-insns-single=500;-mlong-calls;-ffunction-sections;-fdata-sections;-fno-exceptions;-fsingle-precision-constant;-Wall;-Wextra;-Wundef;-Wdouble-promotion;-Wno-expansion-to-defined;-fdiagnostics-color;-std=gnu17
      Id flags: -c
      The output was:
      0
      Compilation of the C compiler identification source "CMakeCCompilerId.c" produced "CMakeCCompilerId.o"
      The C compiler identification is GNU, found in "/mnt/hgfs/vmware/PanelDueFirmware/build/CMakeFiles/3.16.3/CompilerIdC/CMakeCCompilerId.o"
      Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" succeeded.
      Compiler: /opt/gcc-arm-none-eabi/bin/arm-none-eabi-g++
      Build flags: --param;max-inline-insns-single=500;-mlong-calls;-ffunction-sections;-fdata-sections;-fno-exceptions;-fsingle-precision-constant;-Wall;-Wextra;-Wundef;-Wdouble-promotion;-Wno-expansion-to-defined;-fdiagnostics-color;-std=gnu++17;-fno-threadsafe-statics;-fno-rtti
      Id flags: -c
      The output was:
      0
      Compilation of the CXX compiler identification source "CMakeCXXCompilerId.cpp" produced "CMakeCXXCompilerId.o"
      The CXX compiler identification is GNU, found in "/mnt/hgfs/vmware/PanelDueFirmware/build/CMakeFiles/3.16.3/CompilerIdCXX/CMakeCXXCompilerId.o"
      CMakeError.log
      Compiling the C compiler identification source file "CMakeCCompilerId.c" failed.
      Id flags:
      The output was:
      1
      /opt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/bin/ld: /opt/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/10.2.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): in function exit': exit.c:(.text.exit+0x2c): undefined reference to _exit'
      collect2: error: ld returned 1 exit status
      Compiling the CXX compiler identification source file "CMakeCXXCompilerId.cpp" failed.
      Id flags:
      The output was:
      1
      any suggestion on this ?@mfs12
