    RepRapFirmware 3.6.0-alpha.4+3 available for testing
    Beta Firmware
    17
    88
    6.3k
      dc42 administrators @balajiramani
      @balajiramani I'll need to either find a reproducible test case, or add some debug to get more information when this fault occurs.
      balajiramaniundefined 1 Reply Last reply Reply Quote 0
      • balajiramaniundefined
        balajiramani @dc42
        @dc42 Understand. Let me know if I can help in any way.
        • OwenDundefined
          OwenD
          I have just had the same error about 3 hours into a 5 hour print.
          22/09/2024, 1:55:16 pm 	Error: Movement halted because a step timing error occurred (code 3). Please reset the controller.
          Duet 2 WiFi 3.6.0-alpha.5+1
          M122 after error
          M122
          RepRapFirmware for Duet 2 WiFi/Ethernet version 3.6.0-alpha.5+1 (2024-08-31 17:50:58) running on Duet WiFi 1.02 or later
          Board ID: 08DGM-917NK-F2MS4-7J1DA-3S86T-TZTWD
          Used output buffers: 7 of 26 (24 max)
          Static ram: 23360
          Dynamic ram: 72224 of which 12 recycled
          Never used RAM 8368, free system stack 106 words
          Tasks: NETWORK(2,nWait 6,16.3%,202) ACCEL(6,nWait 5,0.0%,345) HEAT(3,nWait 5,0.1%,315) Move(4,invalid,3.3%,266) MAIN(1,running,79.8%,672) IDLE(0,ready,0.5%,29), total 100.0%
          Owned mutexes:
          Last reset 05:49:08 ago, cause: software
          Last software reset time unknown, reason: User, Gcodes spinning, available RAM 19896, slot 1
          Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
          Error status: 0x08
          Aux0 errors 0,2,0
          MCU temperature: min 23.6, current 31.4, max 31.9
          Supply voltage: min 1.1, current 24.3, max 24.6, under voltage events: 1, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/22, heap memory allocated/used/recyclable 2048/1704/1320, gc cycles 572
          Events: 0 queued, 0 completed
          Date/time: 2024-09-22 14:34:22
          Slowest loop: 451.79ms; fastest: 0.13ms
          === Storage ===
          Free file entries: 8
          SD card longest read time 10.1ms, write time 97.4ms, max retries 0
          Segments created 588, maxWait 153529ms, bed comp in use: mesh, height map offset 0.000, hiccups added 276 (8.29ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
          Pos req/act/dcf: 6390.00/6368/0.76 14761.00/14757/0.70 40648.00/40648/0.00
          no step interrupt scheduled
          Driver 0: standstill, SG min n/a
          Driver 1: standstill, SG min 241
          Driver 2: standstill, SG min 0
          Driver 3: standstill, SG min 0
          Driver 4: standstill, SG min 228
          Driver 5:
          Driver 6:
          Driver 7:
          Driver 8:
          Driver 9:
          Driver 10:
          Driver 11:
          === DDARing 0 ===
          Scheduled moves 1473967, completed 1473965, LaErrors 0, Underruns [9, 0, 0]
          Heater 0 is on, I-accum = 0.3
          Heater 1 is on, I-accum = 0.3
          Movement locks held by null
          HTTP is idle in state(s) 0
          Telnet is idle in state(s) 0
          File is doing "G1 X80.404 Y147.896 E.00085" in state(s) 0
          USB is idle in state(s) 0
          Aux is idle in state(s) 0
          Trigger is idle in state(s) 0
          Queue is idle in state(s) 0
          LCD is idle in state(s) 0
          Daemon is doing "G4 S2" in state(s) 0 0, running macro
          Q0 segments left 1
          Code queue 0 is empty
          === Filament sensors ===
          check 79464683 clear 1287376
          Extruder 0 sensor: ok
          === Network ===
          Slowest loop: 117.01ms; fastest: 0.00ms
          Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
          HTTP sessions: 1 of 8
          === WiFi ===
          Interface state: active
          Firmware version 2.1.0
          MAC address bc:dd:c2:89:a0:bb
          Module reset reason: Power up, Vcc 3.38, flash size 4194304, free heap 38948
          WiFi IP address 192.168.1.163
          Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
          Clock register 00002002
          Socket states: 4 5 0 0 0 0 0 0
          EDIT:
          Of interest to anyone testing , I think I've saved the print by turning off the power and recovering from power failure.
          • Kioliaundefined
            Kiolia
            I don't have a way to reproduce yet, but I'm seeing intermittent issues that may be related to machine uptime and/or changes to stepper current settings via M906. Several times now, I have seen a problem where a new print underextrudes severely after 1) running a print to completion and then 2) changing at least one stepper current with M906. There's no sound of step loss or evidence of grinding. As before, this is a 6HC with E on a 3HC as a mixing extruder with 2 steppers at ratios 100% each. I'm running a 0.5 CHT nozzle, but cold pulls after these incidents reveal no debris, and each time I've cold-pulled and restarted the machine, all was fine.
            I wouldn't be reporting this yet, except that today, after the issue repeated, I discovered that I was able to easily hand-feed filament through the extruder while it was tensioned, which is normally only possible on startup before the extruder has been moved -- yet this was shortly after commanding retraction moves to unload the filament and trim the end, so the E steppers must have been at least engaged at idle (set to 25%). M122, M122 B1, and checking the current settings revealed nothing obvious, but the extruder acted like its steppers were unpowered or at least significantly under-currented. I'm pushing my machine hard right now, so it's always possible something else is going on, but I wanted to document this in case it's a thing with the alpha. Also worth noting that I had never clogged this hot end/nozzle before switching to the alpha.
            EDIT: I had not yet switched off the machine, but after reloading the filament and just letting everything sit while I wrote this report, I tried hand-feeding the filament again and it is significantly harder -- more what I'd expect from the idle state.
            Some specifics for the prints I ran this afternoon: I ran a speedbenchy print that finished in 3:36 with no extrusion issues, allowed about 10 minutes for board and stepper temps to steadystate, re-sliced with a change only to accels (100->120k), used M906 to change E current from 1800 to 2000 (a value I've run many times -- I was testing lower current), then ran the new gcode and got the result shown. To my eye this does not look like a clog -- it's too consistent. dc9b91e0-7ea9-49f4-8543-009e12a8e624-image.png
            AWD 48V Duet 3 6HC+3HC Linear Kossel XL "CarbonShrike"
            https://www.printables.com/@Kiolia | youtube.com/@jamespray
            aka Colphaer (Discord) | aka the Deltavangelist | aka that one duct guy
            • gloomyandyundefined
              gloomyandy @Kiolia
              @Kiolia What version of RRF are you using?
              Kioliaundefined 1 Reply Last reply Reply Quote 0
              • Kioliaundefined
                Kiolia @gloomyandy
                @gloomyandy 3.6.0 5+1.
                • Kioliaundefined
                  Kiolia
                  To follow up on the strange extrusion event, I re-ran the same print with the same config settings as before today, and extrusion appeared normal again -- so it wasn't the gcode's fault. Both prints layer shifted and were cancelled at about the same point, so out of curiosity I weighed them. The first one with the extrusion issue weighed 58% of the second one. I wondered if it would be a nice round number like half, but I guess not.
                    dc42 administrators @Kiolia
                    All, please upgrade to 3.6.0-beta.1. If you reported any issues with 3.6.0 alpha releases, test whether they are still present in 3.6.0-beta.1; and if so start a new thread about your issue, including [3.6.0-beta.1] in the topic title.
                    • dc42undefined dc42 locked this topic
