    IR Height Sensor with Klipper
    IR Height Sensor
    • br7408undefined
      br7408
      I am doing a second build of a similar printer to my first (Duet 3 wifi), running Klipper on a BTT Octopus 1.1 instead. I wanted to use the IR Height sensor on this build as well because it works really well with my heated bed (strong magnets).
      I notice on startup, I get 4 pulses (analog) instead of 2 (digital). I do have the pullup signal activated, but I read somewhere about the signal from the board not engaging in time, or similarly needing to add an additional resistor to provide the proper current to activate digital mode.
      I cannot find any consistent information anywhere, though. Are there any known fixes for this?
      The (seemingly) most feasible solution I have read is from the original IR Sensor website that discusses adding a 470 ohm pulldown resistor from the sensor pin to the ground pin.
        dc42 administrators @br7408
        @br7408 try adding a pullup resistor of about 10K between the OUT and Vcc pins of the IR sensor. I don't believe that a pulldown resistor will work.
        br7408undefined 1 Reply Last reply Reply Quote 0
        • br7408undefined
          br7408 @dc42
          Excellent. I actually did more digging around last night and found one of your posts in another forum from many years ago recommending this. I will try it and report back. Your sensor is absolutely the best one out there in my opinion, so I will be happy to get it working on this machine.
          UPDATE: That did the trick David. It is now booting in digital mode. Thank you.
