How to update firmware when DWC doesn't work
A frequent issue I run into when working on our Duet controlled 3D printer, is that when running updates, or changing things, the DWC interface will not launch on the raspberry pi. This is a problem because I can't send it a M997 to update firmware. I can't use a secondary pc to do it because I'm using the hotspot feature on my phone for the raspberry pi as the only source of internet access that I have.
Thanks.
@p8blr One for @chrishamm. Similar issue to https://forum.duet3d.com/topic/36410/restore-dwc-3-5-2 maybe?
@droftarts @chrishamm Would be nice to have a permanent fix. rm .config/chromium/SingletonLock worked for me to
