    set bed temp is not shown on DWC
    Duet Web Control
    • Tinchusundefined
      Tinchus
      Hello. I dont know if this shlould be or not like this: when you execute M140 S60 (just as example), on DWC I should see the bed temp set to 60 degrees or not? beecause the heated bed is heated, but in DWC the set temp area is always in 0, I can see the temp rising on the "current" field, but in active is always cero.
      May be the "active " field is suposed to only show the active configured temperature, but I think it is a little confusing that setting the temperature through a gcode command is not interpreted as the "active" temp.
      This is a DWC 3.5.2, on duet3 + SBC
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
        Can you try clearing your browser cache?
        Tinchusundefined 1 Reply Last reply Reply Quote 0
        • Tinchusundefined
          Tinchus @Phaedrux
          @Phaedrux Done (manually choosing refresh is the same I guess?). Still shows 0 while heating the bed. This is not happening with the hotend temp, as soon as hotend temp is set, the value is updated on DWC
          aceranicundefined 1 Reply Last reply Reply Quote 0
          • aceranicundefined
            aceranic @Tinchus
            I have same issue since upgrade to 3.5.3.
            On PanelDue all is showing fine, on DWC no setpoint temp for Bed.
            Same on 2 laptops and on tablet, phone, etc.
            Also noticed that I cant open local page only using the IP address.
            WiFi server 2.1.0
            More to above, not possible to set presets for Bed. it has memorized presets from Hotend?
            • aceranicundefined
              aceranic @aceranic
              @aceranic Just found other port, it is <single bed control which was on. after off, all is good with Bed temp.
              Also 3.5.3 has issues with WiFi, will try 3.5.4.
