    Lost E value
    • Fuzionlineundefined
      Fuzionline
      Good afternoon,
      When I pause and then restore a print, everything works fine. However, if I restart the duet and run M916, it starts at the position where the pause was made, but it loses the E value from that line of G-code. Only when it moves to the next line of G-code does it start extruding.
      Is it also possible to save the E value along with the (x, y, z) values, as if it were a pause and restore?
      Thank you.
        dc42 administrators @Fuzionline
        @Fuzionline the required extrusion should be restored already. Which firmware version are you using?
        Fuzionlineundefined 1 Reply Last reply Reply Quote 0
          Fuzionline @dc42
          Hello tks
          The version is RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet WiFi 1.02
          resurrect.g resurrect-prologue.g
            Fuzionline @Fuzionline
            @Fuzionline
            Good afternoon! Are there any updates?
              @Fuzionline not yet, but it's on my list to look into next week.
                Fuzionline @dc42
                hello
                Do you have news
                tks
