    Procedure for testing an alpha release
    Beta Firmware
    • mike_bundefined
      mike_b
      Hi everyone, I’m looking to test the latest 3.6.0-alpha release and would appreciate any general advice from the community on how to do this properly. I want to avoid making any mistakes and thus causing unnecessary work for the developers.
      For context, my setup:
      • two Mini5+ boards (the first as the main board and the second as an expansion)
      • one 1LC toolboard, and
      • all in SBC mode.
      When I tested the 3.5.3-beta release, I followed the official procedures by switching to the unstable repo, modifying /etc/apt/sources.list.d/duet3d.list, and then running sudo apt update && sudo apt upgrade.
      However, I'm unsure about the correct steps for testing the -alpha release. Should I simply download the firmware files to the SBC and the expansion board's SD card? And if I do that, will I also need to update the Duet Control Server or Duet Web Server as part of the process? Thanks in advance!
      EDIT: I edited the duet3d.list file to point to unstable-3.6 but running apt list -a duetruntime seems like only 3.6.0~alpha.2 is available:
      $ sudo apt list --upgradable
      Listing... Done
      duetcontrolserver/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duetpimanagementplugin/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duetpluginservice/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duetruntime/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duetsoftwareframework/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duettools/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      duetwebcontrol/unstable-3.6 3.6.0~alpha.2 all [upgradable from: 3.5.3~rc.1]
      duetwebserver/unstable-3.6 3.6.0~alpha.2 arm64 [upgradable from: 3.5.3~rc.1]
      libcamera-ipa/stable 0.3.1+rpt20240906-1 arm64 [upgradable from: 0.3.1+rpt20240829-1]
      libcamera-tools/stable 0.3.1+rpt20240906-1 arm64 [upgradable from: 0.3.1+rpt20240829-1]
      libcamera0.3/stable 0.3.1+rpt20240906-1 arm64 [upgradable from: 0.3.1+rpt20240829-1]
      reprapfirmware/unstable-3.6,unstable-3.6 3.6.0~alpha.2-3 all [upgradable from: 3.5.3~rc.1-1]
        jay_s_uk @mike_b
        @mike_b alpha 2 is the latest DSF firmware available. AFAIK it's fully compatible with alpha 5.1 so you can upgrade to alpha 2 and then upload the firmware files for 5.1
        mike_bundefined 1 Reply Last reply Reply Quote 2
        • mike_bundefined
          mike_b @jay_s_uk
          Hey @jay_s_uk, awesome, it worked, thanks for your help!
