    Help with laser connections and config
    • Alijambo73undefined
      Alijambo73
      I just upgraded ro a duet 3 board and i'm having a struggle to figure out the best way to connect it and then configure the firmware. It will be an addition to a router on the same machine,
      The router is on the out9 using 5V pwm. I was thinking of connectiong the laser to out0 and as I have tested it i hava not seemed to figure out the correct configuration. My other option is to use out7 but im still at a loss on the config and what other files would need to bae added.
      The laser is a NEJE E40 with this interface board
      I have treid it using the Input A connected to the out1 on the duet 3 with the pwm/ttl conected to V_fused and the ground to ground. My preferance woud be to use Input B.
      My reprap knowledge is very basic so any conection and configuration advice would be welcomed. Thanks
        dc42 administrators @Alijambo73
        @Alijambo73 I suggest you use one of the io_out pins to feed the TTL input of that board. As the input is stated to be TTL compatible, a 3.3V signal will be more than enough.
        If the laser turns on at power up then add a pull down resistor between the TTL input and ground.
        Alijambo73undefined 1 Reply Last reply Reply Quote 0
          Alijambo73 @dc42
          @dc42 Thanks for the idea. So I decided to use io3.out. I have this in my config.g
          M452 C"io3.out" F500 R255 S1 ; configure Laser port
          M563 P1 S"Laser"
          is this correct? I don't see anything showing in DWC for the laser, am I missing something, are there any other files I would need to configure outside of config.g?
