    Duet 3 mini5+ randomly resets during printing
    duet 3 mini5+ wifi reset
    645
    • Mauritsundefined
      Maurits
      Since a few weeks my Duet 3 mini5+ randomly resets during a print. This happens mostly during the first layer, sometimes during the second. I've been running a series of prints using the same set of gcode files and seemingly out of the blue this problem is happening almost every print I try.
      My printer is a modified Ender 5 with a Duet 3 mini5+, BLtouch clone and an E3D Hemera direct drive printhead.
      I currently use a standard E3D .4mm nozzle with a generic brand PLA and I've never had any problems with it before.
      Since I know the gcode files are OK I started looking for a hardware fault.
      Most logical cause I thought to be the power supply, so I replaced it. The new one is much more quiet so I'll be keeping that one anyway.
      Checked all the wiring & connections for faults, but couldn't find any.
      I'd really appreciate any help in finding the problem here. I've got a project tot finish before christmas for the 100+ members of my sports club so I'd like to get this fixed really soon.
      I've included the config.g file and the M122 diagnostics file after a reset occurs.
      config.g
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.10 on Thu Jan 06 2022 19:32:52 GMT+0100 (Midden-Europese standaardtijd)
      M575 P1 S1 B57600                            ; enable support for PanelDue
      G90                                          ; send absolute coordinates...
      M83                                          ; ...but relative extruder moves
      M550 P"Pluisje"                              ; set printer name
      M552 S1                                      ; enable network
      M586 P0 S1                                   ; enable HTTP
      M586 P1 S0                                   ; disable FTP
      M586 P2 S0                                   ; disable Telnet
      M569 P0.0 S1 D3                              ; physical drive 0.0 goes forwards in driver mode stealthchop
      M569 P0.1 S1 D3                              ; physical drive 0.1 goes forwards in driver mode stealthchop
      M569 P0.2 S0 D3                              ; physical drive 0.2 goes backwards in driver mode stealthchop
      M569 P0.4 S1 D3                              ; physical drive 0.4 goes forwards in driver mode stealthchop
      M584 X0.0 Y0.1 Z0.2 E0.4                     ; set drive mapping
      M350 X16 Y16 Z16 E16 I1                      ; configure microstepping with interpolation
      M92 X80.00 Y80.00 Z400.00 E394.57            ; set steps per mm old value was E394.67
      M566 X1200.00 Y1200.00 Z60.00 E120.00        ; set maximum instantaneous speed changes (mm/min)
      M203 X30000.00 Y30000.00 Z1800.00 E1500.00   ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z100.00 E250.00         ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                 ; set motor currents (mA) and motor idle factor in per cent
      M84 S300                                     ; Set idle timeout
      ;Pressure Advance
      M572 D0 S0.075                               ; enable Pressure advance
      M208 X0 Y0 Z0 S1                             ; set axis minima
      M208 X220 Y200 Z300 S0                       ; set axis maxima
      M574 X1 S1 P"io5.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io5.in
      M574 Y1 S1 P"io6.in"                         ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io6.in
      M574 Z1 S2                                   ; configure Z-probe endstop for low end on Z
      M950 S0 C"io3.out"                           ; create servo pin 0 for BLTouch
      M558 P9 C"io3.in" H5 F120 T6000              ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X45 Y-4 Z3.460                      ; set Z probe trigger value, offset and trigger height
      M557 X45:215 Y5:195 S27                      ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
      M307 H0 R0.343 K0.363:0.000 D3.36 E1.35 S1.00 B0 ;disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                      ; map heated bed to heater 0
      M143 H0 S110                                 ; set temperature limit for heater 0 to 110C
      M308 S1 P"temp1" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin temp1
      M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
      M307 H1 R2.032 K0.592:0.000 D4.83 E1.35 S1.00 B0 V23.7 ; disable ban-bang mode for heater and set PWM limit
      M143 H1 S285                                 ; set temperature limit for heater 1 to 285C
      M950 F0 C"out5" Q500                         ; create fan 0 on out5 with and set its frequency
      ;M106 P0 C"FAN0" S0.6 H1 T45                  ; set fan 0 name and value. Thermostatic control is turned on
      M950 F1 C"!out4+out4.tach" Q500              ; create fan 1 on out4 with tacho and set its frequency
      M106 P1 C"FAN1" S1 H1 T45                    ; set fan 1 name and value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                             ; define tool 0
      G10 P0 X0 Y0 Z0                              ; set tool 0 axis offsets
      G10 P0 R0 S0                                 ; set initial tool 0 active and standby temperatures to 0C
      ; Filament Monitor
      ;M591 D0 P3 C"io1.in" S0                      ; Duet3D magnetic filament monitor connected to io1.in
      config.g
      M122
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.2 (2024-06-11 17:14:16) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: 7MPG2-K396U-D65J0-40KMQ-JQ03Z-Z0D1Q
      Used output buffers: 14 of 40 (28 max)
      Static ram: 103368
      Dynamic ram: 121568 of which 0 recycled
      Never used RAM 16480, free system stack 198 words
      Tasks: NETWORK(2,nWait 7,10.5%,217) HEAT(3,nWait 1,0.0%,355) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,0.8%,110) MAIN(1,running,86.8%,665) IDLE(0,ready,1.0%,29) AIN(4,delaying,0.9%,265), total 100.0%
      Owned mutexes: WiFi(NETWORK)
      Last reset 00:00:24 ago, cause: reset button
      Last software reset time unknown, reason: HardFault invState, Gcodes spinning, available RAM 27292, slot 2
      Software reset code 0x4863 HFSR 0x40000000 CFSR 0x00020000 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012580 Task TMC Freestk 125 ok
      Stack: 2001948c 20012334 200014e8 e000e000 00000060 00091d55 00000000 6100f000 00000000 00000000 00000000 cf410005 0041ff05 d7000000 0002ff05 3a130000 00000000 00000000 00000000 00000000 00000053 2003b5d0 20012c24 00000dae 20019494 20012e5c 2001261c
      Error status: 0x00
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 24848, completed 24847, timed out 0, errs 0
      MCU temperature: min 31.6, current 31.8, max 32.2
      Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 43, reads 1284, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: standstill, SG min 16, read errors 0, write errors 1, ifcnt 43, reads 1284, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: standstill, SG min 4, read errors 0, write errors 1, ifcnt 40, reads 1284, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 32, reads 1283, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 43, reads 1284, writes 10, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2024-09-17 16:15:14
      Cache data hit count 47397715
      Slowest loop: 14.86ms; fastest: 0.16ms
      === Storage ===
      Free file entries: 20
      SD card longest read time 1.7ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      === DDARing 1 ===
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 0, axes/extruders owned 0x0000000
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      check 0 clear 119043
      Extruder 0: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
      === CAN ===
      Messages queued 223, received 0, lost 0, errs 118088, boc 0
      Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 125/0/0
      Tx timeouts 0,0,124,0,0,97 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 26.64ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 2 of 8
      === WiFi ===
      Interface state: active
      Firmware version 2.1.0
      MAC address d8:bf:c0:15:0a:5c
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42956
      WiFi IP address 172.16.0.142
      Signal strength -40dBm, channel 5, mode 802.11n, reconnections 0
      Clock register 00002001
      M122.txt
      • Mauritsundefined
        Maurits
        I forgot to mention that the issue started while I was running firmware v3.4.6. Unfortunately upgrading to v3.5.2 did not fix it.
          droftarts administrators @Maurits
          @Maurits This has been reported a few times already. See https://github.com/Duet3D/RepRapFirmware/issues/935
          It has been identified why this is happening, and a fix is in the works, should be included in the next update. I was going to suggest downgrading the firmware to RRF 3.4.6, but you say you had the same behaviour there?
          dc42 created this issue in Duet3D/RepRapFirmware
          closed Regular crashes on Duet 3 Mini WiFi #935
          Mauritsundefined 2 Replies Last reply Reply Quote 0
          • Mauritsundefined
            Maurits @droftarts
            @droftarts Hi Ian. Thanks so much for your quick reply.
            I usually keep a log of all the firmware files I've installed over time so I'm quite sure I have this issue with RRF 3.4.6 as well.
            To doublecheck I'll downgrade to 3.4.6 and post the result tomorrow.
            • Mauritsundefined
              Maurits @droftarts
              @droftarts I downgraded succesfully to RRF 3.4.6.
              The first print I ran stopped at layer 4 and the mini5+ reset itself. After trying to run about 20 more prints I notices a few things:
              • during most prints the duet still resets mid-print.
              • the point at which the reset occurs (print file progress) it different each time.
              • only prints with a single object alway succeeed.
              • prints with mutiple objects are sliced to print 'all at once'
              Unfortunately it doesn't make things any clearer to me. Any suggestions?
                @Maurits I don't remember many/any reports of the 'Hardfault' in RRF 3.4.5. It shipped with a different WiFi firmware, 1.27, so if you haven't reverted that (your M122 report WiFi firmware version 2.1.0), you could try that. Though unlikely to make much difference, it is probably best to revert DWC to 3.4.5 as well, if you haven't.
                Mauritsundefined 1 Reply Last reply Reply Quote 0
                • Mauritsundefined
                  Maurits @droftarts
                  @droftarts I reverted to RRF 3.4.5, DWC 3.4.5 and WiFi 1.27 as you suggested and the results are not improving.
                  I dug a little deeper into the forum and found this article about similar symptoms. Although the root cause is very different (and not possible since I don't use an SSR), the direction in which @T3P3Tony was searching might suggest a hardware fault.
                  Could this be worth having a look at or does that seem too unlikely?
                  Maurits
                  wschadowundefined 1 Reply Last reply Reply Quote 0
                  • wschadowundefined
                    wschadow @Maurits
                    @droftarts We're struggling with this issue since months. Yesterday I tried 3.5.3-rc1 and I have the impression that it is more stable on the Ethernet version. The WiFi version of the board crashed once. After turning off WiFi the print (36h) is running.
                    Wolfgang
                      dc42 administrators @wschadow
                      I will be looking into this issue again in the near future. Please post M122 reports following any instances of Hard Fault resets on Duet 3 Mini WiFi running firmware 3.5.3.
                      wschadowundefined 2 Replies Last reply Reply Quote 0
                      • wschadowundefined
                        wschadow @dc42
                        @dc42 Here is a recent M122 with a recent crash. It's a WiFi board. It crashed after about 6h. After that I turned off the WiFi and the 36h print went trough. It also worked fine with the Ethernet version of the board. At the time of the crash it was running 3.5.3-rc1. Today I upgraded to 3.5.3
                        9/20/2024, 3:47:18 PM M122
                        RepRapFirmware for Duet 3 Mini 5+ version 3.5.3 (2024-09-18 11:25:48) running on Duet 3 Mini5plus WiFi (standalone mode)
                        Board ID: UF2UK-QQ6KL-K65J0-409NA-L7X1Z-Z1P2J
                        Used output buffers: 7 of 40 (37 max)
                        Static ram: 103368
                        Dynamic ram: 124872 of which 0 recycled
                        Never used RAM 10272, free system stack 138 words
                        Tasks: NETWORK(2,nWait 7,13.7%,233) HEAT(3,nWait 6,0.0%,347) Move(4,nWait 6,1.0%,241) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,334) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.9%,101) MAIN(1,running,83.3%,665) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,259), total 100.0%
                        Last reset 00:11:41 ago, cause: power up
                        Last software reset at 2024-09-18 17:38, reason: HardFault imprec, Gcodes spinning, available RAM 9992, slot 0
                        Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x0047d803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 482 ok
                        Stack: 2002c658 00000000 200014e4 0000016e 2003387b 00030345 00034d68 81010000 00030331 00000000 00000000 00000000 200316b4 00000800 200363d8 2002c640 2001882c 2002c496 2001882c 2001ea80 000304cb 00000000 00000000 00000000 200120b8 00000014 b5ddb6d6
                        Error status: 0x00
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 526311, completed 526311, timed out 0, errs 0
                        MCU temperature: min 39.0, current 54.7, max 54.9
                        Supply voltage: min 23.4, current 23.8, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/44, heap memory allocated/used/recyclable 2048/1852/1008, gc cycles 8
                        Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 36882, writes 18, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 36877, writes 23, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 36870, writes 30, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 36869, writes 30, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 36882, writes 18, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2024-09-20 15:47:15
                        Cache data hit count 1268256462
                        Slowest loop: 219.27ms; fastest: 0.12ms
                        === Storage ===
                        Free file entries: 19
                        SD card longest read time 7.5ms, write time 1.4ms, max retries 0
                        DMs created 83, segments created 16, maxWait 138693ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                        next step interrupt due in 246 ticks, enabled
                        === DDARing 0 ===
                        Scheduled moves 2280, completed 2275, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3
                        === DDARing 1 ===
                        Heater 0 is on, I-accum = 0.2
                        Heater 1 is on, I-accum = 0.0
                        File is idle in state(s) 3
                        Q0 segments left 1, axes/extruders owned 0x0000807
                        check 0 clear 0
                        Extruder 1: no data received, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                        === CAN ===
                        Messages queued 8614, received 29113, lost 0, errs 0, boc 0
                        Longest wait 3ms for reply type 6013, peak Tx sync delay 194, free buffers 26 (min 25), ts 3508/3507/0
                        Tx timeouts 0,0,0,0,0,0
                        === Network ===
                        Slowest loop: 171.19ms; fastest: 0.00ms
                        HTTP sessions: 1 of 8
                        === WiFi ===
                        Failed messages: pending 0, notrdy 0, noresp 1
                        MAC address c4:5b:be:46:4f:6c
                        Module reset reason: Hardware watchdog, Vcc 3.43, flash size 2097152, free heap 42808
                        WiFi IP address 192.168.3.139
                        Signal strength -55dBm, channel 1, mode 802.11n, reconnections 0
                        • wschadowundefined
                          wschadow @dc42
                          @dc42 here is the config.g as well
                          ; Configuration file for CaribouIDEX with LGX and Duet 3 Mini 5+ (firmware version 3.4 and higher)
                          ; for 0.9° motors on xy, and 0.9° or 1.8° motor on e
                          ; for CaribouIDEX220 Duet3Mini5+ LGX Mosquito 0.9° - E3d or SE Thermistor - SuperPINDA
                          ; CariboDuetConfiguration Release : "0.1.0"
                          ; Build : 177
                          ; Copyright Caribou Research & Development 2023. Licensed under GPL3.
                          ; Source code and release notes are available on github: https://github.com/Caribou3d/CaribouIDEX-Configuration-and-Macros
                          ; global variables
                          global IdleCounter = 0 ; counts idle time
                          global ExtruderTempActive_Old0 = 0 ; stores extruder 0 temperature for idle check
                          global ExtruderTempActive_Old1 = 0 ; stores extruder 1 temperature for idle check
                          global BedTempActive_Old = 0 ; stores bed temperature for idle check
                          global OldStateStatus = 0 ; stores the status of the printer, processing = 1
                          global ToolSelected = -1 ; stores the selected tool
                          global HeatStatus1 = -1 ; stores the status of heater 1
                          global HeatStatus2 = -1 ; stores the status of heater 2
                          global HeatStatus3 = -1 ; stores the status of tool2
                          global HeaterActive1 = 0 ; stores the active temperature of heater 1
                          global HeaterStandby1 = 0 ; stores the standby temperature of heater 1
                          global HeaterActive2 = 0 ; stores the active temperature of heater 2
                          global HeaterStandby2 = 0 ; stores the standby temperature of heater 2
                          global HeaterActive3 = 0 ; stores the active temperature of tool 2
                          global HeaterStandby3 = 0 ; stores the standby temperature of tool 2
                          global HeatStatusTr1 = -1 ; stores the status of heater 1
                          global HeatStatusTr2 = -1 ; stores the status of heater 2
                          global HeatStatusTr3 = -1 ; stores the status of tool2
                          global HeaterActiveTr1 = 0 ; stores the active temperature of heater 1
                          global HeaterStandbyTr1 = 0 ; stores the standby temperature of heater 1
                          global HeaterActiveTr2 = 0 ; stores the active temperature of heater 2
                          global HeaterStandbyTr2 = 0 ; stores the standby temperature of heater 2
                          global HeaterActiveTr3 = 0 ; stores the active temperature of tool 2
                          global HeaterStandbyTr3 = 0 ; stores the standby temperature of tool 2
                          global ToolToActOn = -1 ; stores tool for load / unload / change / filament
                          global zlifted = 0 ; stores status of the z axis
                          global success = 0 ; stores status of load / unload / change
                          global purge = 0 ; stores status to purge when autoloading
                          global AskToChange = 1 ; ask if filament should be changed?
                          global zLiftDistance = 0 ; stores distance for lifting z axis
                          global waitForExtruderTemperature0 = false ; beeps when pre-heat temperature is reached
                          global waitForExtruderTemperature1 = false ; beeps when pre-heat temperature is reached
                          global waitForExtruderTemperature2 = false ; beeps when pre-heat temperature is reached
                          global waitForBedTemperature = false ; beeps when pre-heat temperature is reached
                          global x_accel = 0 ; stores x accelerations (mm/s^2)
                          global x_jerk = 0 ; stores x maximum instantaneous speed changes (mm/min)
                          global y_accel = 0 ; stores y accelerations (mm/s^2)
                          global y_jerk = 0 ; maximum y instantaneous speed changes (mm/min)
                          global filamentErrorIgnore0 = 0 ; enable / disable execution of filament-error.g
                          global filamentTriggerIgnore0 = 0 ; enable / disable execution of trigger2.g
                          global filamentErrorIgnore1 = 0 ; enable / disable execution of filament-error.g
                          global filamentTriggerIgnore1 = 0 ; enable / disable execution of trigger2.g
                          global SkipCalibration=0 ; enable / disable claibration at the beginning of a print
                          ; general settings
                          M111 S0 ; debugging off
                          G21 ; work in millimetres
                          ; network settings
                          M550 P"AM-Xfuse2" ; set printer name
                          M586 P1 S1 ; enable FTP
                          ; drives
                          M569 P0.1 S1 D3 V1000 ; physical drive 0.0 goes backwards - x-axis
                          M569 P0.2 S0 D3 V1000 ; physical drive 0.0 goes forwards - u-axis
                          M569 P0.3 S0 D3 V1000 ; physical drive 0.1 goes backwards - y-axis
                          M569 P0.0 S0 D3 V10 ; physical drive 0.2 goes backwards - z-left
                          M569 P0.4 S0 D3 V10 ; physical drive 0.3 goes backwards - z-right
                          M569 P20.0 S0 D3 V1000 ; physical drive 0.3 goes forwards - extruder
                          M569 P21.0 S0 D3 V1000 ; physical drive 0.4 goes forwards - extruder
                          ; motor Configuration
                          M584 U0.1 X0.2 Y0.3 Z0.0:0.4 E20.0:21.0 ; set drive mapping
                          M671 X-125.1:369.9 Y0:0 S1.00 ; leadscrews at left (connected to z) and right (connected to E1) of X axis
                          ; set Microsteps and steps / mm
                          M350 X16 U16 Y16 Z16 E16 I1 ; configure microstepping with interpolation
                          ;M92 X200.00 U200.00 Y200.00 Z800.00 E704.00 ; set steps per mm
                          ;M92 X200.00 U200.00 Y200.00 Z800.00 E706.00:706.00 ; set steps per mm
                          M92 X200.00 U200.00 Y200.00 Z800.00 E575.00:575.00 ; set steps per mm
                          ;M906 X1400 U1400 Y1400 Z1200 E650 I40 ; set motor currents (mA) and motor idle factor in percent
                          M906 X1250 U1250 Y1250 Z1300 E750 I40 ; set motor currents (mA) and motor idle factor in percent
                          M84 S60 ; set idle timeout
                          ; set speeds
                          M201 X3000 U3000 Y3000 Z500 E500 ; set accelerations (mm/s^2)
                          M203 X12000 U12000 Y12000 Z1000 E3600 ; set maximum speeds (mm/min)
                          M204 P2000 T2000 ; set print and travel accelerations (mm(s^2)
                          M566 X600 U600 Y600 Z48 E300 ; set maximum instantaneous speed changes (mm/min)
                          set global.x_accel = move.axes[0].acceleration ; save accelerations (mm/s^2)
                          set global.x_jerk = move.axes[0].jerk ; save maximum instantaneous speed changes (mm/min)
                          set global.y_accel = move.axes[1].acceleration ; save accelerations (mm/s^2)
                          set global.y_jerk = move.axes[1].jerk ; save maximum instantaneous speed changes (mm/min)
                          M564 H0 ; allow unhomed movement
                          ; axis limits
                          M208 X-72.8 U-37 Y-24.0 Z0 S1 ; set axis minima
                          M208 X251.0 U286.8 Y210.0 Z217.50 S0 ; set axis maxima
                          ; endstops
                          M574 X1 S1 P"io2.in" ; configure active high endstop switch for low end on x
                          M574 U2 S1 P"io3.in" ; configure active high endstop switch for low end on u
                          M574 Y1 S3 ; configure sensorless endstop for low end on y
                          ; SuperPINDA
                          M558 P8 C"^20.io2.in" H1.5 F600 T8000 A3 S0.03 ; set z probe to SuperPINDA
                          M557 X30:230 Y0:200 S30:40 ; define mesh grid
                          ; stallguard sensitivy
                          M915 X S2 F0 H400 R0 ; set x axis sensitivity
                          M915 Y S1 F0 H200 R0 ; set y axis sensitivity
                          M915 Z S1 F0 H200 R0 ; set z axis sensitivity
                          M915 U S2 F0 H400 R0 ; set x axis sensitivity
                          ; heaters & fans
                          ; heated bed
                          M308 S0 P"temp0" Y"thermistor" T100000 B4138 A"Bed" ; configure sensor 0 as thermistor on pin temp0
                          M950 H0 C"out0" Q50 T0 ; create bed heater output on bedheat and map it to sensor 0
                          M143 H0 S110 ; set temperature limit for heater 0 to 110°C
                          ; extruder
                          ; Hotend 1 (Mosquito or Mosquito Magnum with E3d Thermistor)
                          M308 S1 P"20.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Nozzle E0" ; E3d configure sensor 1 as thermistor on pin temp1
                          M950 H1 C"20.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1
                          M307 H1 B0 S1.00 ; disable bang-bang mode for heater 1 and set PWM limit
                          M143 H1 S280 ; set temperature limit for heater 1 to 280°C
                          ; Hotend 2 (Mosquito or Mosquito Magnum with E3d Thermistor)
                          M308 S2 P"21.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 A"Nozzle E1" ; E3d configure sensor 2 as thermistor on pin temp2
                          M950 H2 C"21.out0" T2 ; create nozzle heater output on out2 and map it to sensor 2
                          M307 H2 B0 S1.00 ; disable bang-bang mode for heater 2 and set PWM limit
                          M143 H2 S280 ; set temperature limit for heater 2 to 280°C
                          M308 S4 P"mcu-temp" Y"mcu-temp" A"MCU" ; set virtual heater for MCU
                          M308 S5 P"drivers" Y"drivers" A"Driver" ; set virtual heater for stepper drivers
                          ; fans
                          ; cooling fans
                          M950 F0 C"20.out1" Q500 ; create fan 0 on pin fan1 and set its frequency
                          M950 F1 C"21.out1" Q500 ; create fan 1 on pin fan1 and set its frequency
                          ; extruder fans (temperature controlled)
                          M950 F2 C"20.out2" Q500 ; create fan 2 on pin out5 and set its frequency
                          M106 P2 H1 T50 ; set fan 2 value. Thermostatic control is turned on
                          M950 F3 C"21.out2" Q500 ; create fan 3 on pin out6 and set its frequency
                          M106 P3 H2 T50 ; set fan 3 value. Thermostatic control is turned on
                          ; tools
                          M563 P0 D0 H1 ; define tool 0
                          G10 P0 X0 Y0 Z0 ; set tool 0 axes offsets
                          M568 P0 S0 R0 A0 ; turn off tool 0, set active and standby temperature to 0°C
                          M563 P1 D1 H2 X3 ; define tool 1 (maps x to u)
                          G10 P1 X0 Y0 Z0 ; set tool 1 axes offsets
                          M568 P1 S0 R0 A0 ; turn off tool 1, set active and standby temperature to 0°C
                          M563 P2 D0:1 H1:2 X0:3 F0:1 S"Tool 2 (copy mode)" ; define tool 2 (copies x to u)
                          G10 P2 X0 Y0 U-110 S0 R0 ; set tool 2 axes offsets
                          M568 P2 S0 R0 A0 ; turn off tool 2, set active and standby temperature to 0°C
                          M567 P2 E1:1 ; set mixing
                          M302 S80 R80 ; allow extrusions starting from 80°C and retractions from 80°C
                          ; filament handling
                          ; execute macro that determines the status of the filament sensor
                          ;M591 D0 P3 R60:140 C"20.io0.in" L77.75 S1 ; filament monitor connected to E0_stop
                          M591 D1 P3 R60:140 C"21.io0.in" L77.75 S1 ; filament monitor connected to E1_stop
                          ;M98 P"0:/sys/00-Functions/FilamentsensorStatus"
                          ; other settings
                          M18 XUY ; release / unlock x, y
                          M501 ; load config-override (for thermistor parameters and other settings)
                          G90 ; absolute positioning
                          M83 ; relative extruder moves
                          ; offsets - place off-sets for x and y here. z-offsets are handled in the print sheet macros
                          G31 P1000 X0 Y5
                          G10 P0 X0 ; set offset for tool 0
                          ;G10 P1 X0 Y-0.53 U34.99 Z0 ; set offset for tool 1
                          ;g10 p1 x0 u34.90 y0.47 z0
                          ;g10 p1 x0 u35.58 y0.37 z0
                          g10 p1 x0 u35.43 y0.31 z0
                          T-1 P0 ; deselect tools
                            @wschadow thanks for your report. Please also post the address of the network receive buffer, which you can obtain like this:
                            1. Send M122 P106. Example response:
                            m122p106
                            Platform 2001d138-2001e737
                            SbcInterface 2001e740-2001ea70
                            Network 2001ea80-2001eb67     <---------------
                            GCodes 2001eb70-2001ff6f
                            Move 20023ff8-20024d33
                            Heat 20025110-20025237
                            PrintMonitor 20025240-2002544f
                            FansManager 20025458-200254d7
                            PortControl 200254e0-2002550f
                            Display 20025518-20025533
                            ExpansionManager 20025540-200282f7
                            1. Send M122 P1007 A{0x########+8} where ######## is the first hex value in the Network line of the previous response. Example response:
                            m122p1007 a{0x2001ea80+8}
                            2001ea88: 2002c420
                            1. Send M122 P1007 A{0x########+136} where ######## is the second number in that response. Example response:
                            m122p1007 a{0x2002c420+136}
                            2002c4a8: 20032dd0
                            The second number (0x20032dd0 in this example) is the value I need.
                            wschadowundefined Mauritsundefined 5 Replies Last reply Reply Quote 0
                            • wschadowundefined
                              wschadow @dc42
                              @dc42 here is another one
                              9/20/2024, 8:02:10 PM M122
                              Used output buffers: 11 of 40 (32 max)
                              Static ram: 103368
                              Dynamic ram: 124088 of which 0 recycled
                              Never used RAM 11440, free system stack 190 words
                              Tasks: NETWORK(2,nWait 7,14.9%,228) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.1%,798) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(1,running,83.3%,665) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,259), total 100.0%
                              Owned mutexes:
                              Last reset 00:16:54 ago, cause: software
                              Last software reset at 2024-09-20 19:45, reason: HardFault imprec, Platform spinning, available RAM 9808, slot 1
                              Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00000400 ICSR 0x00000803 BFAR 0xe000ed38 SP 0x20012008 Task NETW Freestk 482 ok
                              Stack: 2002c658 00000000 200014e4 00000165 20033872 0003039d 00034ddc 810f0000 00030389 00000000 00000000 00000000 200326dc 00000800 200363f0 2002c640 2001882c 2002c496 2001882c 2001ea80 00030523 00000000 00000000 00000000 200120b8 00000014 b5ddb6d6
                              Error status: 0x00
                              Aux0 errors 0,0,0
                              MCU revision 3, ADC conversions started 761086, completed 761085, timed out 0, errs 0
                              MCU temperature: min 41.8, current 41.8, max 57.1
                              Supply voltage: min 23.8, current 23.9, max 23.9, under voltage events: 0, over voltage events: 0, power good: yes
                              Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1844/1020, gc cycles 16
                              Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 30, reads 53382, writes 11, timeouts 0, DMA errors 0, CC errors 0
                              Driver 1: standstill, SG min 14, read errors 0, write errors 1, ifcnt 35, reads 53382, writes 11, timeouts 0, DMA errors 0, CC errors 0
                              Driver 2: standstill, SG min 266, read errors 0, write errors 1, ifcnt 42, reads 53381, writes 11, timeouts 0, DMA errors 0, CC errors 0
                              Driver 3: standstill, SG min 310, read errors 0, write errors 1, ifcnt 41, reads 53382, writes 10, timeouts 0, DMA errors 0, CC errors 0
                              Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 30, reads 53382, writes 11, timeouts 0, DMA errors 0, CC errors 0
                              Date/time: 2024-09-20 20:02:09
                              Cache data hit count 1957929928
                              Slowest loop: 9.15ms; fastest: 0.16ms
                              === Storage ===
                              SD card longest read time 3.2ms, write time 0.0ms, max retries 0
                              === DDARing 0 ===
                              === DDARing 1 ===
                              check 0 clear 0
                              === CAN ===
                              Messages queued 9165, received 41127, lost 0, errs 0, boc 0
                              Longest wait 2ms for reply type 6053, peak Tx sync delay 161, free buffers 26 (min 25), ts 5074/5073/0
                              === Network ===
                              Slowest loop: 8.81ms; fastest: 0.00ms
                              === WiFi ===
                              Module reset reason: Power up, Vcc 3.43, flash size 2097152, free heap 39348
                              Signal strength -57dBm, channel 1, mode 802.11n, reconnections 0
                              • wschadowundefined
                                wschadow @dc42
                                @dc42 and the output from 122 p106
                                9/20/2024, 8:04:08 PM M122 p106
                                • wschadowundefined
                                  wschadow @dc42
                                  9/20/2024, 8:07:48 PM
                                  2001ea88: 2002c420
                                  9/20/2024, 8:09:10 PM
                                  m122p1007 a{0x2001eb67+136}
                                  2001ebef: 00000000
                                  • Mauritsundefined
                                    Maurits @dc42
                                    @dc42 I upgraded to RRF 3.5.3 today. During the 2nd print I experienced a hard reset. Please see the M122 report underneath:
                                    Used output buffers: 3 of 40 (18 max)
                                    Static ram: 103368
                                    Dynamic ram: 121604 of which 0 recycled
                                    Never used RAM 16776, free system stack 198 words
                                    Tasks: NETWORK(2,nWait 7,13.5%,217) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.0%,355) CanReceiv(6,nWait 1,0.0%,939) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,334) TMC(4,nWait 6,0.8%,110) MAIN(1,running,84.6%,665) IDLE(0,ready,0.2%,29) AIN(4,delaying,0.8%,268), total 100.0%
                                    Owned mutexes:
                                    Last reset 00:05:29 ago, cause: reset button
                                    Error status: 0x00
                                    Aux0 errors 0,0,0
                                    MCU revision 3, ADC conversions started 247196, completed 247196, timed out 0, errs 0
                                    MCU temperature: min 31.8, current 31.8, max 34.9
                                    Supply voltage: min 23.9, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: standstill, SG min 2, read errors 0, write errors 1, ifcnt 27, reads 17320, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 17320, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 2: standstill, SG min 4, read errors 0, write errors 1, ifcnt 23, reads 17319, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 21, reads 17319, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 27, reads 17320, writes 10, timeouts 0, DMA errors 0, CC errors 0
                                    Date/time: 2024-09-21 16:43:50
                                    Cache data hit count 603090100
                                    Slowest loop: 25.74ms; fastest: 0.16ms
                                    === Storage ===
                                    SD card longest read time 1.3ms, write time 0.0ms, max retries 0
                                    === DDARing 0 ===
                                    === DDARing 1 ===
                                    check 0 clear 1548989
                                    === CAN ===
                                    Messages queued 2965, received 0, lost 0, errs 1595525, boc 0
                                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 26 (min 26), ts 1648/0/0
                                    Tx timeouts 0,0,1647,0,0,1316 last cancelled message type 4514 dest 127
                                    === Network ===
                                    Slowest loop: 28.03ms; fastest: 0.00ms
                                    === WiFi ===
                                    Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42652
                                    Signal strength -47dBm, channel 5, mode 802.11n, reconnections 0
                                      @Maurits Thanks for the report, sorry this is continuing to be a problem. Can you post the same debug info as the post above? See @dc42's post above, here https://forum.duet3d.com/post/345163, for what is needed.
                                      You asked if this could be a hardware fault. Yes, it's possible; I'm not currently sure if the bug we're trying to chase down here is the same one. I'm not aware of other people having the same 'HardFault' reset in 3.4.5. In the past, this fault has usually been to do with static electricity (created by the filament rubbing on the extruder) discharging causing memory corruption. Our general advice to avoid that is here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Power_wiring#grounding
                                      • wschadowundefined
                                        wschadow @dc42
                                        @dc42 Today I tried to tun in SBC mode, this is not stable as well. Here is the output of m122, m122 p106
                                        9/23/2024, 1:44:01 PM	M122
                                        RepRapFirmware for Duet 3 Mini 5+ version 3.5.3 (2024-09-18 11:25:48) running on Duet 3 Mini5plus WiFi (SBC mode)
                                        Used output buffers: 1 of 40 (40 max)
                                        Static ram: 103368
                                        Dynamic ram: 111484 of which 0 recycled
                                        Never used RAM 23684, free system stack 134 words
                                        Tasks: SBC(2,ready,1.8%,813) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.8%,241) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(2,running,95.2%,753) IDLE(0,ready,0.4%,29) AIN(4,delaying,0.8%,259), total 100.0%
                                        Owned mutexes: HTTP(MAIN)
                                        Last reset 00:27:46 ago, cause: software
                                        Last software reset time unknown, reason: User, Gcodes spinning, available RAM 27616, slot 0
                                        Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task SBC Freestk 0 n/a
                                        Error status: 0x04
                                        Aux0 errors 0,0,0
                                        MCU revision 3, ADC conversions started 1250473, completed 1250473, timed out 0, errs 0
                                        MCU temperature: min 34.9, current 46.1, max 55.8
                                        Supply voltage: min 23.4, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
                                        Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1448/624, gc cycles 0
                                        Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 44, reads 22122, writes 26, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 1: standstill, SG min 2, read errors 0, write errors 1, ifcnt 56, reads 22111, writes 37, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 63, reads 22099, writes 48, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 60, reads 22099, writes 48, timeouts 0, DMA errors 0, CC errors 0
                                        Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 37, reads 22122, writes 26, timeouts 0, DMA errors 0, CC errors 0
                                        Date/time: 2024-09-23 12:44:01
                                        Cache data hit count 2957030106
                                        Slowest loop: 433.46ms; fastest: 0.09ms
                                        === Storage ===
                                        SD card 0 not detected, interface speed: 0.0MBytes/sec
                                        DMs created 83, segments created 15, maxWait 132891ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                        === DDARing 0 ===
                                        Scheduled moves 2524, completed 2524, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                        === DDARing 1 ===
                                        File* is idle in state(s) 3
                                        Queue* is idle in state(s) 0
                                        Q0 segments left 0, axes/extruders owned 0x0000807
                                        check 0 clear 0
                                        === CAN ===
                                        Messages queued 19356, received 68219, lost 0, errs 0, boc 0
                                        Longest wait 4ms for reply type 6013, peak Tx sync delay 272, free buffers 26 (min 24), ts 8333/8332/0
                                        === SBC interface ===
                                        Transfer state: 5, failed transfers: 0, checksum errors: 0
                                        RX/TX seq numbers: 52443/3526
                                        SPI underruns 0, overruns 0
                                        State: 5, disconnects: 1, timeouts: 1 total, 1 by SBC, IAP RAM available 0x0cd38
                                        Buffer RX/TX: 0/0-0, open files: 0
                                        === Duet Control Server ===
                                        Duet Control Server version 3.5.3 (2024-09-19 12:12:39, 32-bit)
                                        HTTP+Executed:
                                        > Executing M122
                                        Code buffer space: 4096
                                        Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                                        Full transfers per second: 31.60, max time between full transfers: 278.9ms, max pin wait times: 77.0ms/12.3ms
                                        Codes per second: 2.90
                                        Maximum length of RX/TX data transfers: 4476/1220
                                        9/23/2024, 1:45:38 PM
                                        9/23/2024, 1:45:38 PM	M122 p106
                                        9/23/2024, 1:45:38 PM	Platform 2001d138-2001e737
                                        9/23/2024, 1:51:17 PM	m122p1007 a{0x2001ea80+8}
                                        2001ea88: 2002c420
                                        9/23/2024, 1:52:08 PM	m122p1007 a{0x2001eb67+136}
                                        2001ebef: 00000000
                                        • wschadowundefined
                                          wschadow @wschadow
                                          @dc42 and a second one
                                          9/23/2024, 12:43:41 PM	M122
                                          Used output buffers: 10 of 40 (40 max)
                                          Static ram: 103368
                                          Never used RAM 23900, free system stack 140 words
                                          Tasks: SBC(2,rWait:,1.8%,805) HEAT(3,nWait 6,0.0%,350) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,794) CanSender(5,nWait 7,0.0%,336) CanClock(7,delaying,0.0%,348) TMC(4,nWait 6,0.8%,101) MAIN(2,running,95.1%,753) IDLE(0,ready,1.2%,29) AIN(4,delaying,0.8%,259), total 100.0%
                                          Last reset 00:10:31 ago, cause: power up
                                          Error status: 0x04
                                          Aux0 errors 0,0,0
                                          MCU revision 3, ADC conversions started 474054, completed 474052, timed out 0, errs 0
                                          MCU temperature: min 36.2, current 47.6, max 47.6
                                          Heap OK, handles allocated/used 99/43, heap memory allocated/used/recyclable 2048/1136/312, gc cycles 0
                                          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 33185, writes 23, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 1: standstill, SG min 0, read errors 0, write errors 0, ifcnt 28, reads 33180, writes 28, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 37, reads 33171, writes 37, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 35, reads 33172, writes 35, timeouts 0, DMA errors 0, CC errors 0
                                          Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 33185, writes 23, timeouts 0, DMA errors 0, CC errors 0
                                          Date/time: 2024-09-23 11:41:50
                                          Cache data hit count 1238108594
                                          Slowest loop: 471.26ms; fastest: 0.09ms
                                          === Storage ===
                                          DMs created 83, segments created 6, maxWait 197430ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                          === DDARing 0 ===
                                          Scheduled moves 363, completed 363, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 2], CDDA state -1
                                          === DDARing 1 ===
                                          File* is idle in state(s) 0
                                          check 0 clear 0
                                          === CAN ===
                                          Messages queued 6076, received 25517, lost 0, errs 0, boc 0
                                          Longest wait 2ms for reply type 6031, peak Tx sync delay 153, free buffers 26 (min 24), ts 3157/3156/0
                                          RX/TX seq numbers: 22250/968
                                          State: 5, disconnects: 2, timeouts: 2 total, 2 by SBC, IAP RAM available 0x0cd38
                                          HTTP+Executed:
                                          > Executing M122
                                          Full transfers per second: 30.79, max time between full transfers: 22239.4ms, max pin wait times: 1223.9ms/72.1ms
                                          Codes per second: 1.04
                                          Maximum length of RX/TX data transfers: 4408/888
                                          Send M122 P106
                                          9/23/2024, 12:49:37 PM
                                          9/23/2024, 12:49:37 PM	Platform 2001d138-2001e737
                                          9/23/2024, 12:51:08 PM	m122p1007 a{0x2001ea80+8}
                                          2001ea88: 2002c420
                                          9/23/2024, 12:52:12 PM	m122p1007 a{0x2001eb67+136}
                                          2001ebef: 00000000
                                            @wschadow whatever issue you are having in SBC mode is not the same problem. Please start a separate thread for it, and include in it description of the problem symptoms.
