G94 appears in resurect.g - FFF Mode (3.6.0-alpha.5+1 )
Whilst recovering from a power outage I got an error message saying something like
"Missing or bad parameter"
Whilst searching for a possible cause I noticed that resurrect.g contains G94, which according to the docs is CNC specificG94: Feed Rate Mode (Units per Minute)
CNC specific. Supported from firmware version 3.5
Parameters
No additional parametersShould this command be there and would it cause that error in FFF mode?
; Resume printing file "0:/gcodes/teaser float v9_0.2mm_ABS.gcode" after print paused at 2024-09-22 14:38 M140 P0 S100.0 G29 S1 M568 P0 A2 S260 R215 M486 S0 A"teaser float v9" G21 M98 P"resurrect-prologue.g" X79.673 Y147.873 Z101.620 M290 R0 X0.000 Y0.000 Z0.000 ; Workplace coordinates G10 L2 P1 X0.00 Y0.00 Z0.00 G10 L2 P2 X0.00 Y0.00 Z0.00 G10 L2 P3 X0.00 Y0.00 Z0.00 G10 L2 P4 X0.00 Y0.00 Z0.00 G10 L2 P5 X0.00 Y0.00 Z0.00 G10 L2 P6 X0.00 Y0.00 Z0.00 G10 L2 P7 X0.00 Y0.00 Z0.00 G10 L2 P8 X0.00 Y0.00 Z0.00 G10 L2 P9 X0.00 Y0.00 Z0.00 M486 S0 T0 G54 M106 S0.00 M116 G92 E0.00000 M83 G94 G17 M23 "0:/gcodes/teaser float v9_0.2mm_ABS.gcode" M26 S19492739 G0 F6000 Z103.620 G0 F6000 X79.673 Y147.873 G0 F6000 Z101.620 G1 F3732.2 P0 M204 P50000.0 T50000.0 G21 M106 P0 S0.00 M302 P0 M24
Now the print is finished I have just tested sending G94 from the command line and it gives no errors, so I've answered that half of the question.
@OwenD G93 and G94 are provided for CNC use but are also available in FDM and Laser mode. So G93 or G94 is written to resurrect.g to ensure that the correct mode is restored.
undefined OwenD marked this topic as a question
undefined OwenD has marked this topic as solved
