    Position Z0 impossible avec une sonde SZP
    1
    74
    • Estebanundefined
      Esteban
      Hello everyone,
      I'm having a problem with my homing. I have a switch to set the Z0 (in locurence at home, it triggers when the nozzle is about 1.5 mm from my platen, see homeall.g). Now, when my machine knows the position of its axis, it should be perfectly normal to send a G1 Z0 to bring the nozzle into contact with the platen... However, this is not possible.
      My machine refuses to lower the axis below 0.6 mm. Finally, when I start printing, the nozzle remains +/- 0.6 mm from my platen, even when I adjust the ‘baby steps’ from the control screen. (My machine sends me an error message saying that this point is out of bounds).
      However, my probe does its calibration and a scan of the plate before each print with levelling for the double Z axis, and everything goes very well (apart from an error message from my console telling me that quite a few points could not be reached: see photo). I'm also curious to know what went wrong (same error with much slower speeds).
      So I'm sending you my configuration files here:
      bed.g
      config.g
      config-override.g
      homeall.g
      homez.g
      Thanks you
