    Help with laser not firing
    Laser Cutters
    • Drizz1leundefined
      Drizz1le
      Hi everyone,
      I need help with my laser not firing. Im not sure what the issue is, wether it is hardware or software. My laser is plugged into the "laser" port and I have gotten it to work in the past but then I took a month break and came back and I'm not sure what the issue is.
      My laser is 10W.
      Below is my config file. Can someone tell me if im missing something and what commands to test it?
      I tried turning it on with "G1 X50 S180" but it does not work.
      Thank you
      ; Configuration file for RepRapFirmware on Duet 3 Mini 5+ WiFi
      ; generated by RepRapFirmware Configuration Tool v3.5.4 on Sun Aug 18 2024 18:47:56 GMT-0400 (Eastern Daylight Time)
      ; General
      G90 ; absolute coordinates
      M83 ; relative extruder moves
      M550 P"Laser Duet 3" ; set hostname
      M911 S19.8 R22 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      ; Accessories
      M575 P1 S0 B57600 ; configure PanelDue support
      M552 S1 ; configure WiFi adapter
      M586 P0 S1 ; configure HTTP
      ; Smart Drivers
      M569 P0.0 S0 D3 H50 v50; driver 0.0 goes forwards (X axis)
      M569 P0.1 S1 D3 H50 v50; driver 0.1 goes forwards (Y axis)
      ; Motor Idle Current Reduction
      M906 I30 ; set motor current idle factor
      M84 S30 ; set motor current idle timeout
      ; Axes
      M584 X0.0 Y0.1 ; set axis mapping
      M350 X16 Y16 I1 ; configure microstepping with interpolation
      M906 X1400 Y1400 ; Set motor currents to 1.4A for X and Y axes
      M92 X80 Y80 ; configure steps per mm
      M208 X0:750 Y0:450 ; set minimum and maximum axis limits
      M566 X900 Y900 ; set maximum instantaneous speed changes (mm/min)
      M203 X6000 Y6000 ; set maximum speeds (mm/min)
      M201 X500 Y500 ; set accelerations (mm/s^2)
      ; Kinematics
      M669 K1 ; configure CoreXY kinematics
      M574 X1 S3 ; configure X axis endstop (sensorless)
      M574 Y1 S3 ; configure Y axis endstop
      ; Lasers
      M452 C"laser" R255 F200
      ;M571 P"laser" F200 S255
      M915 X Y S3 R1 F1 H200 ; Adjust H value as needed
        droftarts administrators @Drizz1le
        @Drizz1le What firmware version are you using?
        You don’t appear to have a tool defined, which you need, as it says here: https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_laser#firmware-configuration
        Add this to config.g:
        M563 P0 C"Laser" ; define laser tool
        T0 ; enable laser tool
        I’ll make that a bit clearer in the wiki.
        Drizz1leundefined 1 Reply Last reply Reply Quote 0
        • Drizz1leundefined
          Drizz1le @droftarts
          @droftarts Im using 3.5.3
          Ill test it when im home and let you know.
          Thank you
