    Bad command: Configuration file for Duet WiFi
    Firmware installation
    • Woody78undefined
      Woody78
      after Update to 3.5.3 on my duet 2 wifi at every start it gives me this error message:
      Bad command: Configuration file for Duet WiFi (firmware version 3.3)
      my installation is:
      Duet 2 WiFi 2WiFi 3.5.3
      Duet WiFi Server n/v 2.1.0
      Duet Web Control DWC 3.5.3
      what can i do?
      • chrishammundefined
        chrishamm administrators @Woody78
        @Woody78 Probably you accidentally removed the first semicolon in config.g. Try to prepend ; to that line in sys/config.g and check if the problem persists.
        Duet software engineer
        Woody78undefined 1 Reply Last reply Reply Quote 1
        • Woody78undefined
          Woody78 @chrishamm
          @chrishamm yes, it is. great. thank you... now everything is fine
