CNC pendant encoder skipping step
CNC
  • undefined
    morgoth90
    I was trying the firmware on an Arduino nano: https://github.com/Duet3D/CNC-Pendant-Firmware/tree/master
    After a few fast encoder rotations the detected pulses disalign resulting in two stray pulses after each detected movement:
    pulse1
    pulse2
    pulse3
    pulse4
    MOVEMENT +1
    ... after some fast movements...
    pulse3
    pulse4
    MOVEMENT +1
    pulse 1
    pulse 2
    This behaviour is probably caused by some missed pulse but as result will ignore the first movement in the opposite direction.
    After some tests I fixed the issue rewriting the encoder code using the arduino Encoder library:
    RotaryEncoder.cpp
    RotaryEncoder.h
    undefined 2 Replies Last reply 5 Nov 2024, 14:31 Reply Quote 1
    • undefined
      droftarts administrators @morgoth90
      @morgoth90 Thanks for your 'input'! I've added a note on the Pendant wiki instructions referencing this thread, here: https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_CNC_Pendant#programming-the-arduino-pro-micro
      • undefined droftarts referenced this topic 5 Nov 2024, 15:09
      • undefined
        @morgoth90 Your RotaryEncoder.h file has:
        #include <Arduino.h>
        #include <Encoder.h>
        Can you link to the source of these files? I think Arduino.h is okay (I think it's included in the Arduino IDE), but a link to the correct Encoder.h file is needed.
        See the post in this thread: https://forum.duet3d.com/post/346952
        undefined 1 Reply Last reply 14 Nov 2024, 21:57 Reply Quote 0
        • undefined
          morgoth90 @droftarts
          @droftarts
          Right, probably was included in the available libraries because time ago i was sperimenting with a teensy controller.
          The encoder library is from here:
          https://github.com/PaulStoffregen/Encoder
