    DWC Closed Loop no Autotune
    Duet Web Control
    180
    • wayneosdiasundefined
      wayneosdias
      I cant find the autotune Fx in ClosedLoopTuning-3.5.1
      Ive tried installing ClosedLoopTuning-3.6.0-beta.1, but get a false FW error;
      Otherwise everything seems to work fine. Id really like to use the autotuning feature.
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.5.3 ELECTRONICS: Duet 3 MB6HC v1.01 FIRMWARE_DATE: 2024-09-18 11:27:36
      M115 B50.0
      Duet EXP1HCL rev 1.0a or earlier firmware version 3.5.3 (2024-09-17 14:35:42)
        droftarts administrators @wayneosdias
        @wayneosdias Sorry, I misunderstood, I was looking at your post on my phone. You already have the closed loop plugin installed. I think you have to have recorded a movement for the autotune to be available. See https://docs.duet3d.com/User_manual/Tuning/Duet_3_1HCL_tuning#manual-tuning
        However, the auto tuning function isn't mentioned on that page. I don't have a 1HCL set up to check. Maybe @dc42 or @chrishamm can give you some guidance, if the above doesn't work.
        wayneosdiasundefined 1 Reply Last reply Reply Quote 0
          @wayneosdias use this one: https://github.com/Duet3D/ClosedLoopTuningPlugin/releases/tag/v3.5.1
            wayneosdias @droftarts
            @droftarts I uploaded the file at your link and reboot everything, autotune still not there.
            droftartsundefined 2 Replies Last reply Reply Quote 0
                @wayneosdias I've just been informed that autotune has disabled for the time being, as it needs to be reworked.
                  @droftarts Thanks for the help, Any ideas when it may be up and going?
                  • wayneosdiasundefined wayneosdias marked this topic as a question
                  • wayneosdiasundefined wayneosdias has marked this topic as solved
                    @wayneosdias Unfortunately, no timeline for this work at the moment.
                      @droftarts Understood, thanks again, prevented me from wasting a day chasing my tail 😉
