    Mesh Grid Compensation
    • A Former User
      A Former User last edited by
      So I've finally got my Delta finished but when I try to run Mesh Grid Compensation I get the following error:
      Error: G29: No valid grid defined for bed probing
      I have M557 in my config.g
      I'm running a Duet 0.6 on Firmware Version: 1.20 (2017-12-23)
      Web Interface Version: 1.20-RC3
      What am I missing?
      Paul
      • A Former User
        ; Configuration file for Duet 0.6 (firmware version 1.20 or newer)
        ; generated by RepRapFirmware Configuration Tool on Mon Dec 18 2017 11:03:47 GMT+0000 (GMT)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
        ;M665 R170 L360 B150 H285 X0.0 Y0.0 Z0.0 ; Set delta radius, diagonal rod length, printable radius and homed height
        ;M666 X0.0 Y0.0 Z0.0 A0.0 B0.0 ; Put your endstop adjustments here, or let auto calibration find them
        M665 L360.000 R168.627 H280.965 B150.0 X0.548 Y0.166 Z0.000
        M666 X1.248 Y-0.617 Z-0.631 A-0.20 B-0.00
        M208 Z0 S1 ; Set minimum Z
        M574 X2 Y2 Z2 S1 ; Set active high endstops
        M558 P5 X0 Y0 Z0 H5 R0.4 F1000 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
        G31 P100 X0 Y0 Z-0.15 ; Set Z probe trigger value, offset and trigger height
        M557 R135 S20 ; Define mesh grid
        M92 X160 Y160 Z160 E400 ; Set steps per mm
        M566 X900 Y900 Z900 E1200 ; Set maximum instantaneous speed changes (mm/min)was E1200
        M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)was E1200
        M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)was E1000
        M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
        M84 S30 ; Set idle timeout
        M305 P0 T100000 B4008 C0 R4700 ; Set thermistor + ADC parameters for heater 0
        M563 P0 D0 H1 F0 ; Define tool 0
        M550 PKosselXL ; Set machine name
        M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
        M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
        M586 P0 S1 ; Enable HTTP
        M586 P1 S1 ; Enable FTP
        M586 P2 S0 ; Disable Telnet
        M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
        • Dougal1957
          Dougal1957 last edited by
          maybe the 0.6 doesn't have enough ram to do a grid at that density try changing the S20 in the M557 line to S40 and see if that makes any difference
          • A Former User
            Thanks Doug that's sorted the issue, got it running at S25
