    Upgrade to 3.5.3 failed
    Firmware installation
    535
    • marcel.kastlerundefined
      marcel.kastler @droftarts
      @droftarts Dear Ian, I made it. It worked. I used a DuetPi image and I could flash the 6HC. A bit tedious and I hope that the normal flashing works for the next firmware version. Many thanks for your help and guidance. Would not have been able to do it without you. Thanks.
      droftartsundefined 1 Reply Last reply Reply Quote 2
        droftarts administrators @marcel.kastler
        @marcel-kastler I'm still trying to get a version of Bossa to compile for macOS. I've tried most of the pull requests that make sense in the Shumatec version, but so far no luck. This one seems to be the best candidate for fixing it: https://github.com/shumatech/BOSSA/issues/106#issuecomment-2462378313
        Unfortunately, the author of the fix didn't post all the code, and I'm not able to reconstruct what the intent of the code is to reproduce it. Hopefully they will reply with the full code.
        mbavaro created this issue in shumatech/BOSSA
        open MacOS fails programming SAM S70, Windows succeeds #106
        marcel.kastlerundefined 1 Reply Last reply Reply Quote 0
          @droftarts Dear Ian, your efforts are highly appreciated. However, I consider now to use my 6HC in SBC mode, since I bought a new raspberry. Then firmware updates hopefully become less of a problem since Bossa worked like a charm on your raspi OS.
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
