    best way to check if print is running
    Gcode meta commands
    • cosmowaveundefined
      cosmowave
      Hi all
      If i'd like to check with meta commends if a print is running, which is the best OM value for that?
      I think, there are different possible ways...
      Thanks in advance
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        jay_s_uk @cosmowave
        @cosmowave state.status
        Notepadundefined 1 Reply Last reply Reply Quote 1
        • Notepadundefined
          Notepad @jay_s_uk
          @jay_s_uk Do you know all the possible outputs of state.status?
          I cant seem to find anything in the docs.duet3d page about it
          The real bamboo printer manufacturer
            droftarts administrators @Notepad
            @Notepad See https://github.com/Duet3D/RepRapFirmware/wiki/Object-Model-Documentation#statestatus
            state.status
            Current state of the machine
            This property may be one of the following:
            disconnected: Not connected to the Duet
            starting: Processing config.g
            updating: The firmware is being updated
            off: The machine is turned off (i.e. the input voltage is too low for operation)
            halted: The machine has encountered an emergency stop and is ready to reset
            pausing: The machine is about to pause a file job
            paused: The machine has paused a file job
            resuming: The machine is about to resume a paused file job
            cancelling: Job file is being cancelled
            processing: The machine is processing a file job
            simulating: The machine is simulating a file job to determine its processing time
            busy: The machine is busy doing something (e.g. moving)
            changingTool: The machine is changing the current tool
            idle: The machine is on but has nothing to do
            • mikeabuilderundefined
              mikeabuilder
              You could also read jobs.duration, sleep for a couple of seconds, then read it again to see it it has incremented.
              cosmowaveundefined 1 Reply Last reply Reply Quote 0
                cosmowave @mikeabuilder
                @mikeabuilder it's probably better to check if it is > 0 (or eventually not = "null")
                then, a single reading should be enough
