RRF Config Tool update von 3.3.2 auf aktuell
Hello Duet 3D family
I wanted to update from 3.3.2 after 3 years using the RRF Config Tool and I also read in the JSON - but a lot has changed and I've forgotten a lot. And I just don't understand it anymore! Can someone please help me so that I can at least do an update on the RRF Config Tool. I've attached my config file and the JSON. I'm very grateful for your help. I only save the data using an SD card. Thanks and regards, Alex
config.g
config.json -
@Alex maybe make a backup of that SD card, and then create a new configuration from scratch using the configuration tool and the existing config as a backup.
I do believe the config.g would not require a lot of adjustments except new PID tuning since the parameters changed, but starting over may be a good idea nonetheless. It might be worth re-reading the commissioning guide to re-acquaint yourself with the basics https://docs.duet3d.com/en/How_to_guides/Commissioning
@Alex There were some compatibility issues between the old and new configtool but that's fixed now. On the start page you should be able to click "Load config template" and then load your
config.json
