    Upgraded to 3.6.0B2, Now Wifi not working
    Firmware installation
    • janjohundefined
      janjoh
      So, I was running 3.6.0B1 on my Duet2Wifi and decided to upgrade.
      I uploaded Duet2CombinedFirmware.bin, that brought up the warining about "Please use matching versions" (or some such), that was expected
      I then uploaded
      DuetWiFiModule_32S3.bin
      DuetWiFiServer.bin
      Dialog box asked "Upgrade wifi firmware"? (or similar, can not remember exact wording). the checkbox was "yes" as default
      I accepted.
      Printer rebooted. But never came back on network.
      Serial terminal shows wifi module being stuck in starting.
      Any advice?
      M115
      FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 3.6.0-beta.1 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2024-09-24 10:07:04
      ok
      M552
      WiFi module is being started
      ok
      M552
      ok
      M552
      ok
      M552
      ok
        droftarts administrators @janjoh
        @janjoh Sounds like a failed WiFi flash. Send M122 to get a better understanding of what the WiFi is doing.
        Try sending M997 S1 from the terminal to reflash it. You may need to put the it in idle mode first, with M552 S0, or turn it off with M552 S-1 first. You only want DuetWiFiServer.bin, the other file is for some Duet 3 boards, but it should choose that automatically.
        janjohundefined 2 Replies Last reply Reply Quote 0
        • janjohundefined
          janjoh @droftarts
          @droftarts M122 didn't return anything. But, refresh was an instant success. Thank you
          M997 S1
          Trying to connect at 230400 baud: success, found ESP8266
          Erasing 8192 bytes…
          Erasing 690688 bytes…
          Uploading file…
          5% complete
          10% complete
          15% complete
          20% complete
          25% complete
          30% complete
          35% complete
          40% complete
          45% complete
          50% complete
          55% complete
          60% complete
          65% complete
          70% complete
          75% complete
          80% complete
          85% complete
          90% complete
          95% complete
          Upload successful
          ok
          WiFi module started
          WiFi module is connected to access point Mitt, IP address 172.25.74.150
          • janjohundefined
            janjoh @droftarts
            @droftarts Oh crap.. I just realized that I sent M122 while disconnected.... So that would explain "didn't return anything". As in hitting enter at the end of M122 restarted the serial link.
            Sorry,. I guess we'll never know what it thought it was doing 🙂
            • droftartsundefined droftarts marked this topic as a question
            • droftartsundefined droftarts has marked this topic as solved
