    User interface not responding.
    Duet Web Control
    166
    • ziggymanpopoundefined
      ziggymanpopo
      So here's is an odd one. For some reason I've lost the user interface. It pops up on my phone but it has disappeared on my desktop computer ???? It sent a disconnect error and now won't reconnect. But if I put in the ip address in my phone it is active also on my laptop. I'm using Firefox on desktop. World yesterday but not today and also tried ms edge. Neither one worked. Any ideas???
      • ziggymanpopoundefined ziggymanpopo marked this topic as a question
        ziggymanpopo
        Worked yesterday***
          What firmware and DWC version?
          So it works on your phone, but not your desktop?
          What error do you get in the browser when it fails to load?
          Can you ping the Duet IP address from the desktop when it's not able to connect?
            ziggymanpopo
            No I. Can not it will respond to the ip address on my phone and laptop but not on the desk top. It will do an emergency stop when I do it on the phone. I've tried that and I'll try a reboot on the desktop next this has happened before. It said reconnecting ,,it never did then i closed the browser now the browser says unable to connect. An error occurred during a connection to 10..99.1.....(the ip address) does it maybe have to say http/ also????? A reboot on the desktop didn't do any good either this is an odd one. 🤔
              ziggymanpopo
              Ping I'm not familiar with ???? I just put the ip address in the browser bar and push enter. Is that what you mean??
                ziggymanpopo
                I'm sure it's something with the desktop cause I can print just fine with the slicer program
                  droftarts administrators @ziggymanpopo
                  @ziggymanpopo Do you use the same IP address for connecting to the Duet on your phone, laptop and desktop? Because most likely one of them is wrong.
                  If it's just the desktop browser, maybe clear site data and cookies for the IP address of the printer.
                    ziggymanpopo
                    Droftarts!!! That did!!!! i went into browser history and deleted everything and now it connects if it comes back I'll try to determine what the culprit was. Thank you for the input
                      ziggymanpopo
                      You guys rock !!!
                      • ziggymanpopoundefined ziggymanpopo has marked this topic as solved
