    Paneldue and heat chamber controle
    PanelDue
    • Simon 1undefined
      Simon 1
      Does anyone know how to configure the heater in the heating chamber to be able to adjust the temperature on the paneldue?
      When I try to enter a temperature, it immediately clears when I press set
      Thank's for your help
      Simon 1undefined 1 Reply Last reply Reply Quote 0
      • Simon 1undefined
        Simon 1 @Simon 1
        @Simon-1 said in Paneldue and heat chamber controle:
        By the way i have 2 different firmware version and the 3.5 work but the 3.4... the 3.5 work on my personal printer but
        the one i made a mod is for the company where i work an the paneldue is in 3.4 but the controler is in 3.5.3 i wonder
        if it because of that it not working ??? the problem is the paneldue i receive dont work with the 3.5 firmware the colors
        are weird ! i dont try all the 3.4 version of firmware for the paneldue maybe there a version who working .... I have to
        look for that ....
          What hardware version of panel due is it?
          What do you mean the colors are incorrect?
          • Simon 1undefined
            Simon 1 @Simon 1
            @Simon-1 Thank's for the reply but i find a firmware who working, ... My first two tries with firmware 3.5 did not work I had a black screen and the second time the colors were weird so I tried version 3.4 which worked the first time but I had the problem with the buttons of the heating room which did not work...
            So I decided to retry all the 3.5 firmwares and finally I found one that worked.
            I'm just starting out and I'm not very knowledgeable in programming and I just migrated my printer to firmware 3.5.3 a few weeks ago!!
            there is a good difference between version 2.5 and 3.5.3...
            Currently I am trying to make a trigger to turn on the power supply and turn it off with the same trigger if it is already on...
            The heat chamber is solve !!! 🙂
            droftartsundefined 1 Reply Last reply Reply Quote 1
            • dc42undefined dc42 marked this topic as a question
              droftarts administrators @Simon 1
              @Simon-1 the 3.5 firmware names refer to different hardware versions of the PanelDue. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_PanelDue#find-the-correct-file
