Extrusion length in object model
Would you please consider adding the current extrusion length (per instruder) into the object model? It is available on the web interface. I would use this in a script to determine whether it is worthwhile to clean the nozzle at a tool or layer change.
Thank you! -
@GeneRisi The web interface only displays information from the object model. Is it move.extruders[].position that you are looking for?
@chrishamm Chris, I think it is. Thanks!
