    How do I clear a Heater Fault?
    5.9k
    • Yonkimanundefined
      Yonkiman
      I'm debugging a heater fault issue on my Duet Wifi. What's the simplest way to clear a Heater Fault (don't want to reset the board)?
        https://duet3d.com/wiki/G-code#M562:_Reset_temperature_fault
        • Yonkimanundefined
          Yonkiman
          Thanks, but I should have been more clear: Is there a way to clear it and re-enable it without de-selecting and selecting the tool again (which causes tpost.g, tpre.g, etc.) to run?
            You can prevent the tool change files running by using parameter P0 on the T commands.
            • Yonkimanundefined
              Yonkiman
              Thanks!
