DSF Failed to serialize code
Hi @chrishamm
I had a user try to run the MillenniumOS config wizard yesterday on a new SBC setup of RRF 3.5.4 on a BTT Kraken board, and they received the following errors:
I've not seen this before on a standalone setup, and this may well be the first person to try using SBC mode with MillenniumOS as I personally don't have an SBC setup to test with.
We managed to narrow it down to MillenniumOS usage of html codes within the M291 dialog commands, the file being run to cause these errors is here: https://github.com/MillenniumMachines/MillenniumOS/blob/main/macro%2Fmovement%2FG8000.g
I'm aware that this is problematic if used on something not-a-browser but MillenniumOS was always designed with browser usage in mind, and has been using HTML styling in dialog boxes since very early in development to make some of the information clearer.
Do you think this is something that can be fixed? I assume special characters are limited for some reason but I have no context as to why that would be the case in DSF and not in standalone mode.
