    Connecting Duet Wifi to Delta Printer : Steppers shaking, not turning
    • martinbogo
      martinbogo last edited by
      Hello @DC42,
      I have just built a new delta printer, and I decided to use a 3A/12V power supply and these bipolar steppers:
      http://www.kysanelectronics.com/graphics/1124090-8.3.15.pdf
      The steppers come pre-wired Red-Green-Yellow-Blue ( 1B-1A-2A-2B ). I set M906 to 1200 ( 1.2A ) to derate the amperage by 80% on the stepper. The firmware has been compiled and configured for Delta operation. The endstops are the usual 3.3v makerbot-style mechanical endstops at the top of the towers.
      When I click the "Home" button on the PanelDue, all three steppers just shake violently and do not otherwise move or turn. I checked the stepper phase windings, and they are as the datasheet says they should be.
      Is there something obvious I have missed? Is there something else I need to set in G-Code?
      M350 is set to 16 step microstepping:
      Microstepping - X:16(on), Y:16(on), Z:16(on), E:16(on):16(on):16:16:16:16:16:16:16
      M906 is set to 1.2A for all towers:
      Motor current (mA) - X:1200, Y:1200, Z:1200, E:800:800:800:800:800:800:800:800:800, idle factor 60%
        If the steppers shake violently, that usually means that the phases are not connected correctly. Disconnect the motor cable from the Duet and check with a multimeter that where it plugs in to the Duet, the two wires at one end of the connector have continuity (with a few ohms resistance), and so do the two wires at the other end.
        • martinbogo
          I confirmed that the phases are correctly wired via the "short the phase" test to see if I got resistance when turning the motor.
          I found out that my power supply was fading down to 9.4V under load, and replaced it. The steppers are now running smoothly.
          I also upgraded my duet wifi to firmware 1.20. I'm not sure what version of the PanelDue I have, so I haven't upgraded the paneldue yet… it seems to work fine though.
          I have a new issue, however. I'll start a new forum post to get your help debugging it.
            @martinbogo:
            Thanks, I'll bear that in mind next time someone reports similar symptoms. If the power voltage falls below 9.4V then the firmware turns the stepper drivers off and an under-voltage event is recorded, because the stepper drivers shut down at a slightly lower voltage. You can tell that this has happened by running M122 and looking for "under voltage events" in the report.
