    faulty magnetic assembly?
    Filament Monitor
    • achrnundefined
      achrn
      I've just bought an apparently 100% genuine and unused magnetic filament monitor kit on ebay. Slightly unexpectedly it turned up as a v1 magnetic assembly one (the listing photo was a v2 magnetic assembly, but hey-ho).
      However, the ring magnet rotates freely on the brass shaft. I thought maybe I was imagining it, so I put some dots of sharpie marker on:
      becomes:
      It seems to me there's no point proceeding to try and assemble this, because if the magnet rotates independent of the hobbed assembly it's just not going to work. I assume that's so?
      Next question - is there any way to buy just the magnetic assembly? (I suspect not, but worth asking...)
      • T3P3Tonyundefined
        T3P3Tony administrators @achrn
        @achrn send an email to sales@duet3d.com with where you are located and we will see if we can help you out.
        www.duet3d.com
        • achrnundefined
          achrn
          Just to say (for the record): resolved by Duet3D, I'm very happy with the solution, thanks.
          Now both my printers have functional magnetic filament sensors.
